Previous in Forum: hydrogen extraction   Next in Forum: Monel as Gasket Material?
Storage of Eletrolyte KOH?
06/17/2007 7:44 AM
how to store electrolyte KOH for long peiod of time without any effect on environment and electrolyte. Please give brief procedure. Note, the ambient temperature is 55degree celusious.
Re: Storage of Eletrolyte KOH?
06/17/2007 12:53 PM
A stainless steel container with a Teflon coating perhaps?
06/17/2007 4:00 PM
That's one hell of an ambient. Are you storing in the Middle East or Africa?
06/17/2007 11:08 PM
Have found no problem storing it in black polypropelene containers, I dont think they will be a problem at that temperature. If that is your ambient temperature I would not leave them in direct sunlight.
Good Answers: 120
06/17/2007 11:48 PM
KOH in a sealed black or clear polyethylene or propylene container will last for decades as long as air is kept out and water loss is preventedThe CO2 from the air gradually reacts with it to form a carbonate and in time the crystals will expand and break the container if air gets in. Same thing seen with Nicad batteries and CO2
Per Ardua Ad Astra
Peru - Member - New Member Engineering Fields - Biomedical Engineering - New Member Popular Science - Genetics - New Member Fans of Old Computers - Commodore 64 - New Member
06/18/2007 12:36 AM
The chemical compound potassium hydroxide, (KOH) sometimes known as caustic potash, potassa, potash lye, and potassium hydrate, is a metallic base. It is very alkaline and is a "strong base", along with sodium hydroxide, lithium hydroxide, calcium hydroxide, barium hydroxide and strontium hydroxide.
El compuesto químico del hidróxido de potasio, (KOH) conocido a veces como potasa cáustica, potassa, lejía de la potasa, e hidrato del potasio, es una base metálica. Es muy alcalino y es una "base fuerte", junto con el hidróxido del sodio, el hidróxido del litio, el hidróxido de calcio, el hidróxido de bario y el hidróxido del estroncio.
Properties: Density and phase 2.044 g/cm³, solid - Solubility in water 1100 g/L (25 °C) - Melting point 406 °C - Boiling point 1320 °C - Vapour Pressure 1.3hPa (719 ° C) - Basicity (pKb) -2.29.
How to store: In a glass bottle or polypropelene containers, with hermetic cover.
We must understand the things like are and not to try that they are as we want.
Good Answers: 101
06/18/2007 1:56 AM
Black polypropylene carboys. Keep it in a cool place and tightly capped to prevent absorption of atmospheric CO2 and other acidic gasses.
06/18/2007 3:42 AM
It is common for this material to be stored in polypropylene tanks in UK ambient temperatures.
Anonymous Poster (1); aurizon (1); dbdwoods (1); DVader1000 (1); Grage Tesla (1); jack of all trades (1); PWSlack (1)
