Previous in Forum: Our 12MW ABB Alternator Rotor Got Faulty   Next in Forum: Cable Size Calculation
8 comments
Electromechanical Transients
05/01/2014 2:08 PM
Can anybody tell me the reason of generating the electromechanical transients and why are they below power frequency. Thanks
Re: Electromechanical transients
05/01/2014 2:22 PM
05/03/2014 2:04 AM
Thanks, God bless you
Good Answers: 444
Re: Electromechanical Transients
05/01/2014 4:01 PM
It's actually an advanced phenomena known as Subsynchronous Resonance. They are below synchronous speed because with transients it's the longer time constant system that dominates, in this case the mechanical systems vs. the electrical systems. Every physically realizable system has the potential for resonance as their dynamic effects interact with each other.
In the case of a power system quite a few things affect the position of the rotor, the governor, excitation system, and the load. As the loads are constantly shifting, the governor tries to follow them, as the voltage is constantly changing, the AVR tries to correct it, thus the posistion of the shaft is being constantly jerked around. If the perturbances start building to resonance the forces become huge and can actually shatter the shaft between the generator and the turbine. Google on "subsynchronous resonance" for lots more info.
05/03/2014 2:10 AM
Thank you
05/02/2014 5:28 AM
The rotor (shaft) system of cylindrical (horizontal) generator have their own natural frequencies which decides its "critical speed". One of the critical speed is "Torsional" critical speed. Whenever any electrical disturbance results in change of rotational speed (due to difference in applied torque and the load torque), another torque known as "synchronizing" torque is developed which tries to pull back the system speed to synchronous speed. This takes place at "disturbing" frequency. In this process, the systems "swings" around synchronous speed before coming to steady state condition. This "swing" is at natural frequency of the shaft system. If under any condition, disturbing frequency matches with natural frequency of the shaft system, then "electro-mechanical resonance" takes place. Under such conditions, shaft system may get seriously damaged.
05/03/2014 2:14 AM
Thanks
05/02/2014 11:04 AM
Is this homework? We are not here to short-circuit your education. Electromechanical transients are not usually generated on purpose. They have the frequencies of the mechanical devices. Your post is not stated completely. Give us more information on what you are doing.
05/03/2014 2:15 AM
Thanks
Register to Reply 8 comments
lyn (1); pcchatur (1); RAMConsult (1); Rehman (4); StandardsGuy (1)
