Previous in Forum: Electromechanical Transients   Next in Forum: Power Supply DC-DC Step Up Converter Problem
14 comments
Cable Size Calculation
05/02/2014 2:40 AM
I have to design the cable size for 2000amps load.The distance between is 120 meters.Can you help me in this.
Pathfinder Tags: Cable size calculations
Re: Cable Size Calculation
05/02/2014 6:01 AM
Option 1:
  • Obtain a copy of the relevant national electrical standard (for example BS7671 in the UK, also applicable to Eire and Singapore)
  • Read it
  • Inwardly digest the contents
  • Apply the contents
Option 2:
  • Hire someone who can carry out option 1 somewhat faster.
05/02/2014 2:57 PM
It depends on the supply type, voltage, configuration of equipment....You might have to run several parallel circuits....or possibly a busbar run in a subterranean pipe chase....The first thing I would try to have the original run extended by whomever is supplying the power....
05/02/2014 10:53 PM
What will be the voltage drop per meter of busbar (with a given distance of separation between phases and single or multiple grouped together )carrying rated current?.
pnaban
05/03/2014 12:11 AM
You trollin' me bub?
Good Answers: 181
05/02/2014 4:13 PM
Table 4D1A/B (pages 332/333) or 4D3A/B (pages 335/6) of BS7671 Rev1 2011 will reveal all.
A/ gives CCC
B/ mV/A/M
I could have gone on past experience and been bang on put that would mean me telling you the answer.
Added to which, I had to buy the damn book.
I could look in the American codes but I can't be bothered.
Good Answers: 42
05/03/2014 1:51 AM
No problem Tony. It is very simply. You can look in NEC [NFPA 70] /2011 ed. art.310 Table 310.15(B) 16:
Table 310.15(B)(16) Allowable Ampacities of Insulated Conductors Rated Up to and Including 2000 Volts, 60°C Through 90°C (140°F Through 194°F), Not More Than Three Current-Carrying Conductors in Raceway, Cable, or Earth (Directly Buried), Based on Ambient Temperature of 30°C (86°F):
For 2000 A 4*750 MCM [400 sqr.mm] copper conductor XLPE/EPR insulated.
In order to calculate voltage drop you need the reactance- depending on cable lay-out- and the power factor .
However DIN/VDE 0276-603 recommends 663 A underground for 3*400 sqr.mm [3 single-core cables]. Since no voltage is indicated then shield losses could to be introduced also. But French HN-33-S-52 permits 1090 A [in summer] underground 1000 sqr.mm copper[pvc insulated 70 oC] for 72 kV or more.I still don't know what GOST requirements are.
I recommend-strongly-the second option underlined by PWSlack.
Julius
Good Answers: 203
05/02/2014 10:39 PM
100ea of #12 THHN wires in parallel and electrical tape or wire ties bundling them together. This arrangement will certainly be easier to pull through conduit if that is how you will be holding it in place.
Good Luck, Old Salt
05/03/2014 12:12 AM
If you have to ask this forum for help,why are you in a position to design a power cable?
Refer this to a qualified company or person.
In many countries, it is illegal to perform electrical work without a license.
If you were licensed for the scope of this type work,you would not have to ask strangers for advice.
Good Answers: 102
05/03/2014 1:10 AM
Play with this and you will get some idea of the cable size you need to shunt that 2000A along.
Cable sizing compiles with BS 7671:2008 (IEE Wiring Regulations Seventeenth Edition) and IEC 60364:2001 - See more at: http://myelectrical.com/tools/cable-sizing-calculator#sthash.p4CJ5elZ.dpuf
Then check your local codes to verify
I punched in some numbers and got 630mm2 x 2 in parallel with 8.6% voltage drop. Cu.
Al bigger still.
That's in free air.
Underground or in conduit derates it outside the cable size range.
Good Answers: 42
05/03/2014 8:30 AM
This is a regular question being asked in this forum and I have replied it many times. Why you do not refer previous threads before putting up this thread again and again.
The design of cable size is basic knowledge of an Electrical Engineer and depends on various factors like type of cable being used like PILC, PVC , XLPE etc. Type of cable lying conditions like in trench, cable tray in air, covered by earth, the voltage, ambient temperature, and many more factors. So unless you specify the details no one can give you a proper technical answer.
The cable manufacturers provide the required information and rating of their cable and you can easily calculate the size of the cable required to be used.
Go to any cable manufacturers site they will give you sufficient data to find out your requirement.
05/03/2014 12:49 PM
Please provide the following data:-
1. Supply Voltage
2. Duty factor
3. Power factor
4. Permissible voltage drop
5. Cable laying details
6. Soil details
7. Ground/Air temperature
05/03/2014 3:08 PM
I agree with HiTekRedNek (#7 Comment); not only you are not in conditions to design that cable size, you don`t know how you must to ask. You didn`t make a complete ask; ¿DC or AC? ¿Voltage?
05/04/2014 3:30 PM
See numerous previous threads on CR4 for this commonly-asked question.
Location: KCM, chingola; copperbelt; zambia; southern africa.
05/05/2014 6:54 AM
are you designing or choosing a cable?
an error does'nt become a mistake if corrected!
Register to Reply 14 comments
7anoter4 (1); Aghvel Niazi (1); CARDON (1); DmanEng (1); HiTekRedNek (1); jack of all trades (1); old salt (1); pnaban (1); PWSlack (1); SolarEagle (2); TonyS (1); V.I.Abraham (1); Wal (1)
