Previous in Forum: Difference between LCD & TFT   Next in Forum: Band Stop Notch Filter
8 comments
Trap Antenna
06/18/2007 8:04 AM
Design for wire trap antenna to fit inside a flag pole to operate on 15-20-40-80 meters?
Re: Trap Antenna
06/19/2007 9:29 PM
" Design for wire trap antenna to fit inside a flag pole to operate on 15-20-40-80 meters?"
You need the ARRL Antenna Handbook
The inductances and capacitances must be in line with the radiator which is a requirement that will be difficult if not impossible to achieve with a tubular metal flag pole.
Re: Trap Antenna
07/02/2007 10:02 AM
Stan
I want to use a PVC Pipe for the floagpole.............
Re: Trap Antenna
07/02/2007 10:17 AM
"I want to use a PVC Pipe for the floagpole............."
That might be satisfactory. PVC pipe size & length (heighth) considerations for strength and wind load. Also consideration as to trap coil sizes.
Determine coil and trap dimensions, then select pipe to accommodate coils. Don't forget that a radial grounding system may be required depending on where antenna is mounted.
Re: Trap Antenna
07/02/2007 10:20 AM
What I need is someone to design this thing......
Re: Trap Antenna
07/02/2007 5:27 PM
"What I need is someone to design this thing......"
Hy-Gain has done so.
A Hi-gain Vertical for 10/15/20/40/80 Meters
Note that the lower half is a metal tower. Total height is 53 feet. There is a link on the above page where you can download a 36 page Instruction Manual in .pdf format. study this manual to get an idea of what you what you proposed doing.
A horizontal dipole would probably be a better choice if ground space is available.
Re: Trap Antenna
07/02/2007 8:07 PM
Thanks Stan......I'll give it a look.........
Walt123
Re: Trap Antenna
07/02/2007 8:37 PM
These hams can help you locate a ham near you to give you some personal assistance and advice.
Southeastern Division (Southeastern Division home page)
Director:
Frank M. Butler Jr, W4RH
323 Elliott Rd SE
Ft Walton Beach, FL 32548
850-244-5425
w4rh@arrl.org
Vice Director:
Sandy Donahue, W4RU
PO Box 9424
Dothan, AL 36303
404-403-1513
w4ru@arrl.org
s/Stan
Re: Trap Antenna
07/03/2007 8:53 AM
Thanks Much
Walt123
Anonymous Poster (1); Stirling Stan (4); Walt123 (3)
