Previous in Forum: Turbine   Next in Forum: Generator Cooling (Hydrogen System)
Power Plant - Moisture in Seal Steam
05/09/2014 2:30 AM
What is the effect of moisture in seal steam?( Steam Turbine: SST5-4000F)
India - Member - New Member Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Piping Design Engineering - New Member
Re: Power Plant - Moisture in Seal Steam
05/09/2014 7:51 AM
IMO,
it may eventually lead to corrosion of seal rings.
(engineering)...is the art of doing that well with one dollar that any bungler can do with two..
05/09/2014 7:57 AM
If that were to happen then IMO the rings are made of the wrong stuff.
Good moaning!
Good Answers: 445
05/09/2014 5:38 PM
There should be a labyrinth seal between the seal steam side and the lube oil side that minimizes the crossing of water into the lube oil. Water laden lube oil is a poor lubricant and too much will lead to early bearing failure. Hire a competent turbine engineer ASAP.
05/09/2014 6:17 PM
Please put all your test questions into a single thread so that they may be disposed of all at once.
Register to Reply 4 comments
Crabtree (1); lyn (1); ntr (1); RAMConsult (1)
