Previous in Forum: Power Plant - Moisture in Seal Steam   Next in Forum: Gas Turbine
Generator Cooling (Hydrogen System)
05/09/2014 2:32 AM
what is the effect of increasing pressure in the generator performance?
Good Answers: 109
Re: Generator Cooling (Hydrogen system)
05/09/2014 3:19 AM
If the compressor can compress to a higher pressure it will need more power!
If pressure is your performance measurement it will perform better!
Good Answers: 445
Re: Generator Cooling (Hydrogen System)
05/09/2014 5:44 PM
You need to look at the thermal capability curve for your particular generator. Generally speaking higher H2 pressure results in greater cooling and increased power output from the generator...up to a point. Overpressure the generator and H2 starts leaking through the seals, and we all know how dangerous a H2 fire can be.
05/09/2014 6:16 PM
Please put all your test questions into a single thread so that they may be disposed of all at once.
Register to Reply 3 comments
IdeaSmith (1); lyn (1); RAMConsult (1)
