Previous in Forum: VFD Circuit Diagram in Details   Next in Forum: Conductor Size Required for Transformer, Generator for Frame Earthing
10 comments
Parallel of Two Generators
05/11/2014 4:19 AM
how to take paralel of two generatoer
Anonymous Poster #2
Re: Paralel of Two Generator
05/11/2014 9:33 AM
Hook um together.
Reply Score 2 for Off Topic
Good Answers: 445
05/11/2014 10:47 AM
How to search on your own, check here.
India - Member - New Member
06/17/2014 8:23 AM
Your brilliance has amazed me!
Good Answers: 445
06/27/2014 1:30 PM
That may be, but it doesn't appear to have worn off on you.
05/11/2014 5:33 PM
It depends. Generally it is far cheaper and easier not to.
Reply Score 1 for Off Topic
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Technical Fields - Technical Writing - New Member
Re: Parallel of Two Generators
05/12/2014 11:33 PM
Just Google it, refer Books, ask experts...
Do not do it yourself..you may ruin everything..
Location: KCM, chingola; copperbelt; zambia; southern africa.
05/13/2014 2:30 AM
http://www.aksapowergen.com/354E54F6-6534-43E9-8935-3AE197387430/FinalDownload/DownloadId-DB1B8ECFEDF53B93EFA5BCCAB7E4CA73/354E54F6-6534-43E9-8935-3AE197387430/pdf/other/Parallel+Generators+Synchronization.pdf
an error does'nt become a mistake if corrected!
06/17/2014 8:22 AM
Syncing 2 generators,
Phase should match, Frequency should match, and of course,voltage, power and current.
06/27/2014 9:06 AM
No, not current, and therefore not power either.
Good moaning!
Good Answers: 445
06/27/2014 1:39 PM
You must strike the word "should" and substitute "must", then drop power and current as Crabtree has said.
Now tell us, how are you going to know when the phase, frequency, and voltage all match? And do you even know if these generators are capable of being synced? A mistake will be deadly.
Anonymous Poster (1); Crabtree (1); DmanEng (1); jack of all trades (1); RAMConsult (3); tasneemahmd (2); vishram lele (1)
