Previous in Forum: Parallel of Two Generators   Next in Forum: Relay Time Discrimination
17 comments
Conductor Size Required for Transformer, Generator for Frame Earthing
05/11/2014 2:10 PM
What is the required conductor( frame to earth electrode) size for transformer, generator frame earthing with reference standard?
Fakrul
Good Answers: 140
Re: Conductor size required for transformer, generator for frame earthing
05/11/2014 3:06 PM
According to the codes and standards in effect where this is being installed. With the complete lack of information in your post, no other answer is possible.
05/12/2014 9:41 AM
Thanks for your response. Please consider it for BS/IEC/NFPA.
Fakrul
05/11/2014 3:11 PM
Impossible to answer, except to say, the correct one per local and national codes.
Do a search; here's one:
IS SP 30: National Electrical Code : Bureau of Indian ...
Re: Conductor Size Required for Transformer, Generator for Frame Earthing
05/11/2014 10:29 PM
It is about this big.
If you really don't wish to duplicate this type of wiring then you should understand your circuitry a little better than what you've told us and consult with the wiring authority for this installation.
05/12/2014 3:53 AM
British Standard 7671 gives full protocols for cable sizing, as has been repeated in this forum on countless previous occasions.
Reported as a possible duplicate thread.
05/12/2014 10:05 AM
What is the fault current at the transformer, generator?
05/12/2014 1:19 PM
Thanks for your response.Please consider 1000 KVA, 11/.415 KV ,Dyn 11 Distribution transformer.
Fakrul
05/12/2014 1:59 PM
In all the power plants I have been for the last 40 years, the wire size is a minimum of 1/2 inch. I do not know what the actual wire size is. There are so many different grounds in a plant that it seems to be a standard size due to the fact that it is not load bearing. Check local codes to get the correct size.
05/12/2014 6:02 PM
Do not confuse Grounding with Grounded, a common mistake.
The largest conductor going to the electrode,in the ground,is #6 Copper.
There are exceptions ,of course, to every rule, and this rule is no exception.
Per NEC,article 250.
Read and understand this section thoroughly before proceeding.(CYA)
05/12/2014 8:16 PM
I did not get confused. He is grounding the FRAME and not grounding the load.
05/12/2014 8:36 PM
My reply was directed to the OP,not you.
05/13/2014 2:47 AM
Thanks for your response and cooperation. I need conductor size from frame to the electrode. Could you please provide me the clause no from Artical 250 of NFPA that I can check. Actually I am confused about the issue and want to make my conception clear.
Fakrul
Good Answers: 181
05/13/2014 9:08 AM
If you're going to check on the answers given, why not look for the conductor size yourself.
You could give the size of the conductor that you've calculated and we'll tell you if you're right.
In other words "do your own work."
05/13/2014 9:16 AM
As I stated,it is important that you read and understand the Article 250.
To give you a portion out of context would be dangerous.
You must understand the theory as well as the process to safely perfom electrical installations.
If you do not understand it on first pass,do some further research or experience to enlighten yourself.
The code book is not designed to be a cookbook,with recipes on "how-to-do", it is merely stating what must be done to achieve a safe installation.
There are so many variations on installations that a strong undestanding of priciples is required.
This is why many years of experience is required before a hopeful electrician can even apply for a license.
Memorizing the entire code book will not get you there.
This is not an exclusive club, to exclude others, rather all who are qualified are welcome.
General advice is all I can give you for the safety of all concerned.
Good Answers: 170
05/14/2014 6:40 AM
Please inform me your mail ID thro this forum's mail box so that I can send you a chart on the same.
Good Answers: 42
05/23/2014 1:03 AM
See also: British Standard BS 7430 Code of practice for Earthing
Ch.18-19 [mainly 19.7.2 Size.
IEEE-Std 665-1995 IEEE Guide for Generating Station Grounding
ch. 5.3 Generator and isolated phase bus grounding
Julius
05/23/2014 1:37 PM
Thanks for your response and guidence.
Fakrul
Register to Reply 17 comments
7anoter4 (1); beentheredonethat (1); electricalexpert65 (1); fakrul143 (4); HiTekRedNek (3); lyn (1); North of 60 (1); PWSlack (1); redfred (1); TonyS (1); valkyrierider (2)
