Previous in Forum: Radio Mast Earthing   Next in Forum: Domestic Low Voltage DC Supply
R/I converter
06/19/2007 6:28 AM
What is the R/I converter Input: slide wire 100-10000 ohm
0utput: 4-20mA
Supply: 24-240VAC/DC
plz need ur help
BR
M.K
Re: R/I converter
06/19/2007 6:48 AM
Any chance of a digital picture?
Re: R/I converter
06/19/2007 7:37 AM
unfortunatly no but i gaus it's type of ommeter convert from ohm to current
Good Answers: 54
Re: R/I converter
06/19/2007 11:52 PM
The question is a bit vague. But.
The position of something could change a resistance. The resistance value is then converted into a form that can be read by a PLC. eg A dancer arm position can be fed into the 4-20mA inputs of a VSD, to trim linespeed.
Throw it into the draw, it may come in handy someday. Jeff
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
Re: R/I converter
06/20/2007 2:50 AM
R/I converter is Resistance to current converter. In your case when the resistance of the slide wire is 100 ohms the current will be 4 mA, and when the resistance is 10000 ohms the current will be 20 mA , in between the current output will be proportional to the resistance. . More details are required about the exact application.
NatNat7
Re: R/I converter
06/20/2007 9:03 AM
Not really knowing wether you HAVE or you WANT a schematic - you may look at TI.COM at the XTR101 - XTR117 series to get an idea of how these converters work and can be applied.
Good luck
Uwe
The sum of intelligence on earth is a constant. And the population grows and grows and .....
Re: R/I converter
06/20/2007 3:29 PM
In these Control-Topology the controls values used are to vary the output value from min to max by:
1. 4-20 mA
2. 0-20mA
3, 0-10 V
4. (-)10 -0- (+) V
5. 0-10KΩ
etc etc
Almost in majority of Control-values a Variable resistor is used to Vary the Output values fom min to max.
Actually the Input to R/I or R/V converters is the variable voltage varied thru var resistor. It is normally multi-turn.
Re: R/I converter
06/20/2007 10:49 PM
Well, it is resistance to current converter. Usually it is use as a positioner, the slide is mechanicaly link (linkage) to a valve opening ang closing, or a linear mechanism to and pro.
Converter alone is not enough. the control Loop includes your controller in which reads your 4-20 mA from your converter as a min max position, your controller has also an output, defending on the input of the actuator you need, 4-20 mA, 0-20 mA, 0-5 V, 0-10 V etc, the actuator converts the electrical signal to mechanical action, from 0 - 100 % actuation.
Now a days it not only connected to actuators, connected to PLC and do a multi task job, control speed, volume, heat anything you can measure.
Available this days were positioner using infra-red, laser to achieve a high degree of control.
This control loop are the heart of most of the industrial processes if no all.
Register to Reply 7 comments
Anonymous Poster (1); ffej (1); Haajee (1); M.K (1); NatNat (1); PWSlack (1); uweka (1)
