Previous in Forum: Pump Motor On A Generator   Next in Forum: Rise in Temperatire of Transformer High Voltage and Low Voltage Winding
Rise in Transformer Oil Temperature
05/13/2014 9:35 PM
what are the causes of rise in transformer oil temperature and the solution.
Re: rise in transformer oil temperature
05/13/2014 9:41 PM
What do you think the cause might be?
Then if you can decide that, you can work on the solution.
Have you done any research on the specific transformer you have or is this homework?
If you really have a transformer, call an electrician.
Location: KCM, chingola; copperbelt; zambia; southern africa.
05/14/2014 4:37 AM
http://en.wikipedia.org/wiki/Transformer_oil_testing
http://www.electrical4u.com/transformer-oil-and-winding-temperature-rise-test/
an error does'nt become a mistake if corrected!
Good Answers: 445
Re: Rise in Transformer Oil Temperature
05/14/2014 4:51 PM
The cause is energizing the transformer, the solution is to keep it de-energized. Seriously, the oil in a transformer is there to provide insulation and cooling. Anything electrical that has current flowing through it heats up as a result of I²R losses, more current more heat. The oil in a transformer moves that heat from the windings and core to the outside world without ever touching it except through a heat exchanger.
Do some basic research into "transformer cooling/heat rise" to learn more.
05/14/2014 10:29 PM
Is this a home work or what?
Register to Reply 4 comments
DmanEng (1); lyn (1); RAMConsult (1); Simon Wan (1)
