Fellow Engineers,
The Tennessee Valley Authority has done pioneering work on septic system design wherein the waste water or effluent is pumped alternately between rock filled tanks. A bacterial slime quickly forms on the surface of the rocks. The alternate pumping allows the bacteria to oxygenate and switch their basic metabolism from anaerobic to aerobic. In the aerobic mode the bacteria are at least ten times more efficient at removing or reducing dissolved solids and reducing the oxygen depleting effects of waste in water.
I believe that this basic technology can be adapted to clean and oxygenate free flowing surface waters such as rivers and streams.
Designing a impoundments strewn with rocks is within my civil engineering capabilities. However, for the system to work well there must be at minimum two impoundments that can be alternately filled and then drained on a two to four hour half cycle. Ideally the sluice gates to handle this control function would be reliable, robust, easily maintained and ideally self actuating.
Does anyone have any practical experience with such systems or an interest in developing a working system. There is a large amount of federal money set aside for mine waste de-acidification which is one potential application. I am most interested in wildlife restoration and flood control applications which also have some funding potentials.
Thank you,
Mr. Gee
