Previous in Forum: Purer Streams - Engineered Waterway Regeneration   Next in Forum: Timetrevelling
steam turbine eff calculation
06/20/2007 1:37 AM
sir,
can u teel how to calculated the steam turbine themal eff
Re: steam turbine eff calculation
06/20/2007 3:51 AM
South Africa - Member - ShoSholoza Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member
06/20/2007 4:48 AM
Efficiency is the ratio of [power output / power input].
The input power is calculated from the difference in energy enthalpies between the inlet & exhaust steam conditions of the steam i.e the pressure & temperature at inlet & exhaust conditions need to be known and the enthalpy is obtained from steam tables. You also need the steam flow rate.
Output power would be obtained from measuring / calculating the power that the turbine performs e.g when driving an electrical generator, the output is generally measured, when driving a pump, the hydraulic power can be calculated. In both these instances allowances must be made for:
1. the efficiencies of the generator [85% ?] and the pump [65% ??]
2. frictional losses in bearings etc.
You can get quite fancy and make allowances for heat loss from the casing & piping, steam losses from leaks and blow vents..... It would depend on the accuracy that you are after and the boundary limits that have been set.
Can you imitate yourself?
