Previous in Forum: Why the Official Explanation of MH370’s Demise Doesn’t Hold Up   Next in Forum: One Way Speed of Light
15 comments
Why Not Detergent Oil In a Barber Chair
05/16/2014 10:42 PM
Several posts mention to use 30w oil in barber chair hydraulics. Just wondering what the problem is with using detergent oil?
Re: Why Not Detergent Oil In a Barber Chair
05/16/2014 11:01 PM
Several posts?
Where?
Why would you question those posts?
Yes, "several" sites I searched also suggested non-detergent 30W oil.
Knowing nothing about the seal materials used in barber chairs, why would you question several posts which recommend not using detergent oil.
I don't.
Good Answers: 50
05/16/2014 11:27 PM
As Lyn indicated, the problem will be the seals damaged by the detergent additives.
ignator -
05/17/2014 8:26 AM
Thanks Ignator. Appreciate the straight up answer.
05/17/2014 8:26 AM
but how will he flush out all the by-products of combustion suspended in the oil?
05/17/2014 10:22 AM
Because you're supposed to use shampoo oil--detergent is too harsh.
05/17/2014 5:11 PM
10aWapuhi30
05/17/2014 11:53 PM
If the chair has any brass parts in contact with the oil,the high zinc content of H D oil could cause abnormal wear.Also the old seals were probably leather,which can be softened by the detergents and lose sealing ability.
05/18/2014 12:00 AM
those old chairs have a lot of mileage on them. perhaps high mileage oil would be best
05/18/2014 11:11 AM
I have seen "Oilite"sleeve bearings clogged by high detergent oil,resulting in lack of lubrication and bearing failure.
These bearings are made of bronze or brass powder that is compressed into a bearing shape.
The gaps between the particles become a reservoir for oil to lube the bearings.
Whithout these open pores,the oil cannot reach the inner surface of the bearing.
Non-detergent oil is not hard to find, so where's the problem?
Or are you just curious about why they specify non-detergent oil?
If so,perhaps I have answered some of your questions.
05/18/2014 11:28 AM
Most auto parts stores will have hydraulic jack oil, it might be a better choice.
05/18/2014 6:16 PM
On sea platforms they use canola for hydraulic oil to minimize environmental contamination.
05/19/2014 12:09 AM
Really?
Is canola oil use as a hydraulic fluid on sea platforms limited to barber chairs? or are there other places as well?
I wonder if there are any figures available to support this claim...kind of sounds like oil firm PR departments working overtime, attempting to convince people they deserve an f'ing cookie or something, rather than something that make a big difference.
05/19/2014 12:12 AM
Was this practice pioneered on the Deepwater Horizon?
05/19/2014 5:33 AM
Thin ice! Proof it or die (Do Indepth Examination)!
Good Answers: 266
05/19/2014 9:53 AM
I believe there is some mix up here. That that should be an ISO 32 grade oil. A hydraulic oil. ISO 32 grade is about a 10 w oil. Knowledge of pump jacks in which the pump and the displacement cylinder of a barber chair are similar. A 30 w motor oil oil has a viscosity too high to flow properly into the pump. And if we are talking a 30 w motor oil the viscosity my be even higher. As the oil is formulate to work under elevated temperature. The detergents in motor oils and those in hydraulic oil differ. Those detergents in motor may degrade the hydraulic seals.
If you can't find a 10 w hydraulic oil. Automatic Transmission fluid would be a better replacement.
Also I also have seen vegetable oil used in hydraulic systems. Wouldn't recommend it. Vegetable oils are made of many different fats and oil extracted from the plant. Some of which will evaporate over time which will leave fats that gel and form solids. These solids will contaminate seals and block ports.
Register to Reply 15 comments
Charlie Greenwood (1); Fredski (1); HiTekRedNek (2); IdeaSmith (1); ignator (1); JE in Chicago (1); johnnydh (1); lyn (2); ozzb (1); Solararts (1); Tornado (1); truth is not a compromise (2)
