Previous in Forum: Paper Production   Next in Forum: Flex to cable connection
Types of Stainless Steel
06/20/2007 10:39 AM
Is 303 stainless steel the same or close to blue tampered stainless steel?
Good Answers: 27
Re: Types of Stainless Steel
06/20/2007 11:57 AM
I'm not sure what blue tempered stainless steel is but tempering implies a heat-treatable stainless which is only possible with martensitic grades (403, 410, 414, 416, etc.). 303 is austenitic and is hardenable only by cold-working; not hardenable by heat treatment. The third stainless steel type is ferritic which is not hardenable by heat treatment or cold work.
06/21/2007 9:07 AM
303 is indeed an austenitic stainless and it can be surface hardened through a low temperature heat treatment known as Kolsterising. It is not a through hardness but can be very effective if your looking to reduce wear or galling related issues. There is no dimensional change to the treated component. The process can create a hardness of 68-70 HRc. Worth a look.
www.kolsterising.info
Good Answers: 243
06/21/2007 11:21 AM
Low temperature carburization process. creates a high carbon case on the surface of the part.
Relatively rare in application so far as I know. Thanks for sharing. this.
Milo
06/21/2007 3:38 AM
BillM (1); Bluestone (1); Milo (1); PWSlack (1)
