Previous in Forum: Allowable Stress limit in hydrotest   Next in Forum: Hydraulic Fluid Calculations
Clean water supply plastic pipes
06/20/2007 12:33 PM
thankfully any one briefs me the major types of the plastic pipes for the use for the domestic clean water supply.
Re: Clean water supply plastic pipes
06/20/2007 11:53 PM
hi there;
1. p v c [ solvent weld ] 2 . c p v c [ solvent weld ] 3. pex [ mechanical crimp ]
Good Answers: 21
06/21/2007 6:24 AM
water suppliers also use polyethelene pipes. But I'm guessing the original post is asking what pipes are used from the main stop valve to the house in question.
06/21/2007 5:52 AM
Underground domestic water supply piping is nowadays done in 20mm Ø polypropylene, coloured blue to distinguish it from gas supply, which is yellow.
06/22/2007 3:46 AM
Correction: polyethylene. (Polypropylene is poly-methyl-polyethylene, really.) [The end of the roll that was used for routing services to a new extension wasn't available for inspection until arriving home last night, and the memory is becoming a forgettory.] Either polyethylene or polypropylene would be entirely acceptable, though polypropylene tends to be a bit more flexible.
06/21/2007 11:28 PM
round here between meter and haus / abs black plastic with barb
connetions[ does not like strain ]
/ blue polyethylene [pex ] barb connections /
06/23/2007 9:49 AM
Hi There,
Here in Australia I am building a small house [ Studio ] on our property alongside the existing one & did a bit of research on plastic piping because of the big increases of the price of copper piping & fittings, came across an article that said that if a rat or other rodent chewed thru the in-wall or cavity plastic piping & it flooded your house out ,your insurance company WON'T pay any compensation, so I am going to stick to copper pipe & copper & brass fittings soft soldered or silver soldered . I might use it to run mains water to the studio where it is completely external but I certainly am not going to use any plastic on internal in-wall cavity fit-out.
Brien.
Register to Reply 6 comments
Anonymous Poster (1); KLYSTRON (2); MACA (1); PWSlack (2)
