Previous in Forum: Disconnector & Switch Disconnector Help   Next in Forum: API 505 and IP 15
IEC Test Recommendation Varistar and HV/LV Distribution Fuses
05/21/2014 10:05 AM
Were are experiencing problems accountable with indoors and outdoor busbar .These kinds of probs normally resulted to burning of arrestors (varistar having the following specifications; design voltage,rated voltage 33Kv,In=10KA) and fuses (Un=36Kv, In=25A,I3<3*In and I1=20KA ABB type for Distribution) .I know absolutely how to test fuses but ma Big prob's is how to Test Surge arrestors or Varistar.Could Someone tell me indeed what are the recomanded Test for new and old(not broken) Arrestors before installation or energizing to the system ??
"The best thing one can do when it's raining is to let it rain".
Henry Wadsworth Longfellow (American poet 1807-1882)
Re: IEC TEST RECOMANDATION VARISTAR AND HV/LV DISTRIBUTION FUSES
05/21/2014 10:21 AM
Yes, YouR electrician can.
33Kv can kill you instantly if you have no clue. You have no clue.
HIRE AN ELECTRICIAN OR ENGINEER.
Re: IEC Test Recommendation Varistar and HV/LV Distribution Fuses
05/21/2014 4:17 PM
Proper quality control testing is not simple or cheap and it is VERY unlikely the surge arresters are faulty, more likely they are dying due to over voltage events (voltage surges, lightning, etc) or due to incorrect surge arrestor selection.
Get someone qualified in to check the site, otherwise the problem is likely to continue to occur.
05/22/2014 2:34 AM
"The things here's is that..we have plenty of pieces in our show cases (store) and specification never been a compromised.Still my question is how to test these staff's when we put them into system most of them resulted to failure after sometimes.Could anybody suggest me how to Test them??
" best thing one can do when it's raining is to let it rain".
Good Answers: 131
05/23/2014 2:25 PM
As Jack of all Trades said, it is unlikely that your arresters are failing because they are faulty, especially if the last a while before failing. If you don't know how to test them, you certainly do not have the skills and knowledge to test them. It is not a task for the untrained and unequipped. Better to hire a qualified testing company to do that for you.
But as was also said, the likely cause is overvoltages or surges that are beyond the capability of the arrestors to withstand. They are doing their job, to protect the rest of your system! You need to do more investigation of the electrical supply to see where and why it is out of tolerances.
Anonymous Poster (1); jack of all trades (1); lyn (1); PeterT (1)
