Previous in Forum: Coversion of Deg C to Kilowatt   Next in Forum: US Shale Oil Downgrade - What Should We Learn?
9 comments
PVC Extrusion/Calendering
05/24/2014 4:48 AM
Our f-PVC processing of 1.5 & 1.2mm sheet runs troublesome, i.e. the product shows bubbles, some look like ripped open and dragged along; others look like cavities. I admit our dry-blend is not dried, nor do we have a vent on the planetary extruder. Our individual components show indeed excessive moist pick-up.
In my opinion, I would like to dry the dry-blend and vent the cold mixer. However, I do contemplate placing a vent on the planetary extruder but am afraid of extracting the placticiser.
Further, I am aware the bubbles may be caused by air entrapment in the powderblend. Is there a possibility to densify the blend before feeding it into the extruder?
Installing a vent and a dryer seems overkill. Advantages/disadvantages of one or the other ? Investment numbers ?
How should I proceed?
Re: PVC Extrusion/Calendering
05/24/2014 11:45 AM
Garbage in-garbage out.
If you put wet compound, with trapped air into your extruder, this is what you will get.
Extrusion does not keep the material under sufficient pressure while the extrudate is solidifying. So bubbles grow.
Dry the material, then remove excess air.
05/24/2014 2:03 PM
Thanks,
you're actually saying put in the dryer AND the vent.
05/24/2014 2:28 PM
All my experience is in injection molding.
Consider my opinion nothing more than a guess.
Talk to some extruders. Look for a thermoplastic processors forum and ask them.
05/24/2014 2:56 PM
Fire Lawrence Welk and his infernal bubble machine, and your problem will be solved.
05/24/2014 10:36 PM
We had 40 injection molding machines in one plant and most of them had dryers to maintain quality.. It appears to be mandatory in some conditions.
Good Answers: 153
05/25/2014 4:40 AM
Putting the feed hopper on resilient mounts and vibrating it (small amplitude, high frequency) will knock air out of the mix, but moisture is a more likely cause for your problems. Note over vibration will create bridging problems.
05/26/2014 1:54 PM
interesting to say the least. Are there any papers on the subject showing the effect of vibration on the number of air inclusions in the sheet please?
Good Answers: 153
05/26/2014 6:37 PM
I do not know of any papers on this subject, my suggestion is only based on experience if handling powder blends for other process feeds. Before spending heavily on permanent equipment you could improvise some tests with temporary kit to see what works.
A pneumatic vibrator suspended in the feed hopper from it's air feed line would simulate vibrating the hopper. Make sure you pipe the exhaust out of the hopper. If your product does not improve you have eliminated one possibility at a very low cost.
Make up a blend and dry it off line, (your ingredients suppliers or the extruder manufacturer may be able to make up test samples if you do not have the facilities in house), but improvising a solution is better because you can you can create different degrees of dryness to test. If drying out the mix solves the problem you will also have data to help specify the degree of dryness required then buying a permanent drier solution.
05/26/2014 10:06 AM
you blend must be dry this is typical of moisture also in hi humidity if the delivery system starts and stops can condensate it is best to dry product in a nitrogen atmosphere or best results
Register to Reply 9 comments
Anonymous Poster (1); Ghost (2); jhhassociates (2); lyn (2); pcman101 (1); roy hammy (1)
