Previous in Forum: Linux Download   Next in Forum: Microsoft Office 365, What a Waste! Or Am I Being Unfair?
Ticking in My WAV File
05/25/2014 6:58 AM
I am trying to make a tone file and it is working. but it is not sounding the way I want it to sound. There is a low tone beat in the file. that I did not add to it. And I do not know why it is there..
Someone told me to try fading out / fade in and not just going down to 0 and I did but it did not work.
can anyone help me ?
I just need to remove the ticking and output the right Frequency
here is my code:
tone = new isochronicTone(); tone.SetWaveFormat(44100, 2);
double time = Convert.ToDouble(time2.Text) / 2.2675;
time = time * 50000D; double Amplitude = Convert.ToDouble(Peaktxt.Text);
SaveFileDialog save1 = new SaveFileDialog();
save1.Filter = "Wave file (*.wav)|*.wav;";
if (save1.ShowDialog() != DialogResult.OK) return;
WaveFileWriter wavefile;
wavefile = new WaveFileWriter(save1.FileName, tone.WaveFormat);
double counter3 = 0;
double tenp = 0;
double Ptemp = Peak3 - 0.001D;
int newcounter = 0;
if (Beat3 != 0)
Beat3 = (1 / Beat3);
tenp = Beat3/(1D / 44100D);
else
Beat3 = 0;
for (int n = 0; n < time; n++)
if (counter3 >= Beat3 && Beat3 != 0)
for (int t = 0; t < tenp; t++)
if (Ptemp > 0.000005)
float temo = (float)(Ptemp * Math.Sin((((Math.PI * n * (Frequency3))/2) / 44100D)));
wavefile.WriteSample(temo);
n++;
Ptemp = Ptemp - 0.001D;
newcounter++;
else if ((tenp - newcounter) <= 0 )
n++;
Ptemp = Ptemp + 0.001D;
else
wavefile.WriteSample(0F);
n++;
counter3 = 0;
else
float temo = (float)(Peak3 * Math.Sin(((( Math.PI * n * (Frequency3))/2)/44100D))); wavefile.WriteSample(temo);
counter3 = counter3 + (1D / 44100D);
Ptemp = Peak3 - 0.001D; newcounter = 0;
wavefile.Flush();
wavefile.Dispose();
if (waveout == null)
waveout = new WaveOut();
waveout.PlaybackStopped += onPlaybackStopped;
MixingSampleProvider mixer = new MixingSampleProvider(WaveFormat.CreateIeeeFloatWaveFormat(44100,2)); audioFileReader = new AudioFileReader(save1.FileName); mixer.AddMixerInput((ISampleProvider)audioFileReader);
SampleToWaveProvider mixer3 = new SampleToWaveProvider(mixer);
try {
waveout.Init(mixer3);
waveout.Play();
} catch
MessageBox.Show(" Error retry");
waveout.Stop();
waveout.Dispose();
waveout = null;
return;
What am i doing wrong ?
here is how it sounds:
https://onedrive.live.com/redir?resid=CC8AF223519E2440!119&authkey=!AAFtwo79tic33IA&ithint=file%2c.wav
Pathfinder Tags: wave File
Re: ticking in my wav file
05/25/2014 11:55 AM
Good Answers: 1147
Re: Ticking in My WAV File
05/25/2014 7:29 PM
I can't exactly follow your code right now, but I do recall once generating a white noise file to play through headphones to help me concentrate in an office with a lot of "collaboration" going on.
I set it up to play the file in a loop. There's always a click between when the file play ends and it starts again. Maybe that is what is going on here. Sorry I can't help any more.
05/26/2014 11:44 AM
Why can't you use audacity and a few plugins to create this?
What I hear is your tone is pulsed. You may have created the wave form fine, but it may not have enough durration and/or is leaving a gap between sections of tone.
What is the target frequency, waveform, and duration?
I just looked at it in Audacity and what you have is a square-wave that rises several times and then goes flat until the next burst, just like it sounds. You should download Audacity (free) and take a look at what you made. Then, just use the built in signal generator and make one that is right.
Register to Reply 3 comments
Deefburger (1); Rixter (1); SolarEagle (1)
