Previous in Forum: Harmonic reduction   Next in Forum: Current Measurement
PSU/CPU queries and information required
06/25/2007 1:54 AM
Hi all
Some questions in regards to electrical components that I'd appreciate detailed input on (though I may know many answers, second and third opinions are always a bonus), even guidance on where to find more knowledge as the ambiguity around online has increased. The more detail, the better.
Good quality computer PSUs: (i.e. Etasis ET850, Enermax Galaxy DXX/Infinity, Thermaltake Toughpower and so forth)
-Are Ultra PSUs any good, any model or series at all that anyone knows about (like the X2 and X3)?
-Can you list your top 3 most reliable PSU brand/series choices for desktop PCs? (any wattage)
-What is an approximate temperature range modern PSU internals can sustain with ease without any damage or decrease in output quality, sustained over prolonged timescale usage (say 12-36 months)?
-Is running a PSU at 25% it's total output capacity better for it's longevity/performance, 50%, 75% or 100% and to what extent is this crucial?
-What are overclocked quad core QX6800 (4GHz) with 8800GTX in SLi (655/2200), 4GB RAM, a sound card and 4 drive WD Raptor HDDs in RAID0 capable of pulling in VDC Watt power at peak? What is the peak and average VDC power draw of most enthusiast-high end computer systems nowadays would you estimate? 800-1000W possible or only at 300W peak?
-How much will it affect a PSUs output power quality and internal components to run a given PSU, say Corsair 620HX, at 100% rated output load, at 35C inlet air, 24/7 for 12 months? Will it last, or how long approx.? Any unwanted effects?
-How serious is line noise/ripple for computer components (over 50mV p-p on 12V)? Anything we should worry about, as in will cause damage? Imminent failure?
Is this a perfect method of testing/marking PSUs or is anything wrong with it? http://www.jonnyguru.com/review_details.php?id=112
Microprocessors, such as Intel Core 2 Quad/Extreme/Duo and AMD X2:
-How bad is heat for a CPU:- Will 60C after 10 minute 100% load on a processor (say Core 2 Duo) have any unwanted detrimental effects, or is running 50C idle system temps just fine without any damage? (regardless of ambient air temperature due to different cooling methods)
-Is there a temperature specification whereby the (any) CPU will fail? (where can I find them if so)
-**What sets the clock speed frequency of the CPU on AMD socket 462 CPUs (the dependencies)? What can affect it and make it read falsely and how to get the accurate readings when this happens?
-Is there anything that you know as being the most accurate at reading internal core frequencies, with the least margin of error, even after overclocking?
-Is there ANYONE who can present a freak scenario whereby an Athlon reaches 13000MHz because the PLL timers or something other was faulty (explain what please)? Is this possible?
-Would faulty motherboard PLL timers be able to kill other system components reproducibly within hours of usage?
Very lengthy and at times vague generalizations I know (make best estimates), my apologies, but this is for many people not just me, and I've read this place for a long time now being a GlobalSpec member to come to expect professionalism and intelligible input from here, as always.
Thankyou all.
Kalim
Re: PSU/CPU queries and information required
06/25/2007 10:10 PM
Regards.
On PSU there is another discussion. find it in cr4.
Computer_Problem
Computer problem (Software & Programming)
<http://globalspec.ip09.com/rd/9z1z6k4691ldqsrqulcdmbcfgo4pkjkis5uvikhcllg>
A verstyle tool to check PSUs Voltage quality and more:
http://www.almico.com/sfdownload.php
SpeedFan 4.32
If you need a tool that can change your computer's fan speeds, read the temperatures of your motherboard and your hard disk, read voltages and fan speeds and check the status of your hard disk using S.M.A.R.T. or SCSI attributes, then you came to the right place. SpeedFan is the software to go. It is fully configurable and you can create custom events to handle every situation in an automated way. SpeedFan works under Windows 9x, ME, NT, 2000, 2003, XP and Vista. SpeedFan works fine on Vista 64 bit too. The relevant driver is now signed with my digital certificate. And this all costs you absolutely nothing!
SpeedFan allows you to have a deeper view of the status of your computer. Almost every computer includes support for hardware monitoring. Accessing digital temperature sensors is really useful. If you are trying to figure out why your pc hangs when under heavy load or after some hours of usage, SpeedFan might help you to find the real cause. Very often it is a poor power supply, or an improperly installed heatsink that lead to behaviours that we tend to associate with errors from the operating system, but that are not. SpeedFan automatically searches your computer for interesting chips: the hardware monitor chips. SpeedFan can expose voltages, fan speeds and temperatures. On rare occasions, the BIOS doesn't activate such features. SpeedFan tries to enable them as long as this is a safe thing to do. Not only the motherboard is searched, but also some video cards and almost every recent hard disk. SpeedFan can access status info from EIDE, SATA and even SCSI drives, showing, in a consistent way, internal data that can be used to diagnose current and future hard disk failures. This is known as S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology). At the lowest level, SpeedFan is a hardware monitor software that can access digital temperature sensors, but its main feature is that it can control fan speeds according to the temperatures inside your pc, thus reducing noise.
Hope of some help !!!!
06/26/2007 10:27 AM
I've run my athlon at 1800 at 1.5 GHz / 50C for years, only problems are dodgy connections on the IDE ribbon. My old athlon 1500 cooked when the fan cut out because nothing throttled it when it got real hot- now it's a refrigerator magnet.
I'm told Intel put throttling and temp sensing on the CPU with the P4 and Celerons of that era, so an overtemp will result in slowing down or hanging instead of a cooked CPU. Current Athlons may do so at this point as well, it's been a few years.
When I was researching the issue, I think I dug up a CPU damage threshold of 280 F from AMD's website, however system stability will go south long before then.
06/26/2007 12:03 PM
Your PSU question are answered in PSU manufacturer site.
I like Enemax. Keep you PSU above 50%. Don't remember exactly but I think PWM power supply don't like too low loads.
For total power use, get rating from manufacturer. For CPU multiply normal power with ratio you OCed.
Heat is bad for all electronic. Keep it as low as possible for longest life.
The closer to 100% load the PSU is, the harder for it to keep voltage stable. Any extra load will make the whole system unstable.
All clock speed are not exact. It always fluctuate. You can never measure correctly when your measuring component base it clock on the CPU clock. You need something with an external clock higher then the one you want to measure.
Pineapple
Just a few words
06/29/2007 1:52 AM
Hi all, Kalim again (the topic starter)
Many thanks for all your replies. I know electrical engineers are around, I thought they could answer these questions in technical depth.
Jaajee, moon161, Pineapple: all many for your input!
I read the link you gave but mine is more of a technical discussion of knowledge than "support". I don't require help with a computer I'm having a problem with, I can do all that stuff as long as it's Linux, BeOS and Windows.
I know the basics about computing/hardware/software/programming/overclocking etc, been into for a very long time, know most reviewers of hardware around and some company reps too, so I do have a lot of their side info. I can bench a PSU with an ATE and an Oscilloscope, replace motherboard/PSU capacitors and so on, no problem.
Yes, I've used Speedfan for long, but many times BIOS and every other software is not correct so I just use k type diodes and a DMM instead - I'm told by all specialists and electrical engineers that this is the ONLY way that's correct to measure temps and rail voltages.
The PSU manufacturers say hardly anything and most of what they say is old market speak now. They just try to advertise their own products.
I know most of the latest on PSUs aswell out there (online) but the questions I asked were to get technical and in-depth info on matters by people who know more than me and about topics that I don't know fully nor well.
I'd love some in-depth and electrical engineer advice thanks, or by anyone who knows more in-depth about my queries. So far what's covered is within my knowledge.
Appreciate all the help and will wait for more.
07/04/2007 6:21 AM
Thanks all anyway.
Anonymous Poster (3); Haajee (1); moon161 (1)
You might be interested in: CPU Cards and Modules, CPU Chips, CPU Fans and Coolers
