Previous in Forum: Metamaterial is Super Slippery   Next in Forum: Flixborough - 40 Years On
Material Selection
05/30/2014 3:09 AM
hi,i want to fabricate a disc plough which can work in clayey and sand soils,which material should i use and why
learning is a continous process.
Re: material selection
05/30/2014 3:49 AM
Study which materials have been used on existing ploughs, evaluate them, reject the worst and select the best.
  • One wouldn't use expanded polystyrene, for instance.
Re: Material Selection
05/30/2014 11:27 AM
High strength steel.
Fans of Old Computers - PDP 11 - New Member
Location: In a mushroom field somewhere in Canada. Kept in the dark and fed sh--, well you know.
06/02/2014 7:26 AM
Good Job lyn,
Did you Google this too? Please advise.
UFG Forever
Dirt is for vegetables. Pavement is for racing.
06/02/2014 12:08 PM
CR4 ADMIN: Deleted Post
Irrelevant This post was deleted because it is related to a deleted post and would otherwise be taken out of context.
05/30/2014 4:25 PM
disks are ordinary 1050 to 1070 carbon steel.and a layer of 12-14% Manganese Steel will make it high resistance to wear i am suggesting you because it used on the mixing blades of concrete mixers and gives long life span.
love4everyone
05/30/2014 6:22 PM
Are you fabricating this disc plow for your own use, and as such intend to repair/reface the discs as needed yourself?
Or are you intending to market the disc plow? If so, that market will be important to you selection of material. Do you hope to sell replacement discs/repair, i.e. do you hope discs or repairs will be continuing revenue stream? Will the customers you are targeting pay a premium for going longer between disc repair/replacement?
Register to Reply 6 comments
lyn (2); PWSlack (1); sohail0110 (1); truth is not a compromise (1); unclefastguy (1)
