Previous in Forum: Gravity Die Casting   Next in Forum: Capabilty Machine to Drill 0.1mm Dia
Heat Treatment
05/30/2014 3:16 AM
can someone help me and explain to me what is meant by annealing,and then differrciate btn heat treatment and annealing
learning is a continous process.
Re: heat treatment
05/30/2014 3:47 AM
Good Answers: 266
Re: heat treatment
05/30/2014 8:26 AM
Did you even Google the word annealing? Can't differentiate between the two as annealing is a heat treatment.
Good Answers: 151
Re: heat treatment
05/30/2014 9:48 AM
"Heat treatment" is any thermal process applied to a material (ie. a metal alloy) in order to make a permanent change to one or more of its its physical properties. These processes usually involve a phase change or change in the crystal structure of the material.
Annealing is one form of heat treatment used to soften or increase the ductility of a material.
Good Answers: 70
Re: Heat Treatment
05/31/2014 12:00 PM
Heat treatment = Pi$$ing people, wanting them to do your homework for you. They get Hot and Hard nosed about it. Annealing = someone being Soft Hearted and gives you the correct answer for your homework assignment.
You might also want to search the internet for "Ice Box Rivets" and why they are called that.
Register to Reply 4 comments
Anonymous Poster (1); dj95401 (1); gringogreg (1); ozzb (1)
