Previous in Forum: Piglauncher Construction Code   Next in Forum: Methods of Repairing Storage Tanks
8 comments
Inserting Pogo Pin Automatically
05/31/2014 11:26 AM
Is there a machine to run auto to insert pogo pin into socket holes. I mean hundreds of pogo pins are being inserted manually using twizer. Anyone can help?
Re: Inserting pogo pin automatically
05/31/2014 11:34 AM
05/31/2014 11:50 AM
Thank you sir. Can I find this machine elsewhere in Malaysia? How much would it be caused? The pogo pin size is 0.14mm, can the machine insert it?
05/31/2014 12:54 PM
Most suppliers are in China, but you might find a distributor in your area....Search Alibaba for a supplier to meet your needs, and call them for information....
http://www.alibaba.com/showroom/automatic-pin-inserter.html
05/31/2014 8:20 PM
Thos pins are big big pins... Mine are at 0.2 to 0.3mm mm sizes. These pins are used in sockets for testing.
05/31/2014 9:07 PM
So contact them and tell them what you need....If they can't supply or build the machine, they should give you a lead to who does....
06/03/2014 5:06 PM
Alexander Graham Bell can solve this problem. You see, he invented the telephone.
Good moaning!
05/31/2014 10:08 PM
I do not come here to run errands for you.
Learn how to search for what you need!
<unsubscribe>
Re: Inserting Pogo Pin Automatically
06/01/2014 7:09 AM
Register to Reply 8 comments
Crabtree (1); Fathil (2); lyn (2); SolarEagle (2); Tom_Consulting (1)
