Previous in Forum: Testing for Affect of Ocean Front   Next in Forum: Inserting Pogo Pin Automatically
11 comments
Piglauncher Construction Code
05/23/2014 4:24 AM
I want to fabricate couple of pig launchers to be used in oil field for pigging purpose.I prefer ASME codes for construction.I know that pipeline construction code for the transportation of liquid hydrocarbon is ASME B31.8 B31.4. Can I use ASME B31.4 for pig launcher construction or should I go for ASME BPVC Sec VIII Div-1?
Re: Piglauncher construction code
05/23/2014 8:38 AM
05/23/2014 11:40 AM
Good thing my mouth was empty or I would have spit it out from laughing so hard.
GA
J B
05/23/2014 11:58 AM
Are you still using age old technology?
http://keydesigneng.com/blog/2011/04/20/pig-launcherpig-receiver/
05/23/2014 12:05 PM
Although I do know what piglauncher is, I do not have a correct answer for the code you are looking for. I was going to apologize for my pic but I see you have a sense of humor too. Hopefully someone will have a serious answer for you.
Re: Piglauncher Construction Code
05/23/2014 11:41 AM
Don't let PETA find out what you want to do. They'll protest and boycott you.
J B
05/23/2014 12:02 PM
Thanks.
I found this in intenret
05/23/2014 5:03 PM
Why not see what the commercial companies do?
Pig launcher and receiver stations - DKG-EAST Zrt.
Search for them.
05/24/2014 4:32 AM
Thanks lyn for the link.Today only I checked my client spec. properly. Impact test is mandatory if we follow the code mentioned in our client spec.
Pig traps are simple things.It can be fabricated from line pipe materials. reducer portion only need rolled plate.It is not big equipments like reactor or regenerator.I have seen plenty of pig traps installed in middle eastern oil fields.
Good Answers: 34
06/09/2014 7:11 PM
CHIKE 2011
The design of a pig luncher or receiver involves,
a) A good knowledge of the ASME Codes in particular ASME Sec VIII div 1, ASME B31.4 and B31.8. and B31.3
You need the above knowledge to be able to do the following
Wall thickness calculations for the major barrel, minor barrel, the reducer and the End cover.
Other cal calculations of reinforcement of nozzle opening are also necessary.
Support saddle calculations are also required.
b) However before you can commence the calcolations you need to get the process parameters of pressure, temperature, density, viscosity, etc of you process fluid;gas or liquid.
06/12/2014 9:17 AM
This is sample calculation. Nest page of this book diskus about nossle calculation
06/12/2014 11:17 AM
end cover calcullation
from which code I can get saddle calculation? should I refer pressure vessel design books?
Register to Reply 11 comments
JBTardis (2); JPool (2); lyn (1); sanweld (5); Whitephone (1)
