Previous in Forum: Calculate Air flow   Next in Forum: NPSM female to NPT male
15 comments
Brick Making Machine?
06/26/2007 10:09 AM
Hello Engineers, Can anyone help me make a brick making machine ? Does anyone have experience in these type of machines ? PLEEEESE HELP! Thanks. Zeelo
Re: brick making machine?
06/26/2007 10:18 AM
Hi again, the machines i have seen have a vibrator which presses down the mixture into the mould then releases the bricks onto a board which is left outside to dry & harden. I am looking to build a machine like this.
Popular Science - Cosmology - New Member United States - Member - New Member
06/26/2007 9:37 PM
Hello zyhlo,
Check out this brick making machine forum.
Regards,
-John
All worthwhile programmers know that constants always vary.
Good Answers: 101
Re: Brick Making Machine?
06/26/2007 11:59 PM
Check out the following website. It shows you the components of a brick-maker in the correct sequence. Hope it helps you determine what you need.
http://www.rictec.com.sg/brick/
06/27/2007 5:46 AM
Hi, those machines are too large & expensive. Im trying to build a small machinery with a vibrating press which presses down the mixture into the mould then releases it. Can anyone help?
06/27/2007 6:39 AM
how do you plane to place the concrit mix in to the mold?
06/27/2007 7:00 AM
I plan to use labour or automate it if possible.
06/27/2007 7:32 AM
You need hydraulic cylinder and an electric motor to begin with.
Build a mold that opens in the middle and will open and shut by hyd cylinder to relies the brick from the mild
On a frame place another hyd cyl that will have the inserts for the hollow space in the brick, and on top of the plate, place the motor with an eccentric weight on the shaft that will bring the vibration.
06/27/2007 8:21 AM
You will also have to have a brake on the vibrator to stop the vibration before the brick is realeased from the mold. Electro brakes are available for this purpose. I made cinder blocks back in the 60's using several machines over the years. All of them used a box open at the botom and top and shaped for the block being made. A movable platform that could be raised to close the bottom of the mold, supported a steel plate for the fresh blocks to set on. material was dumped into the top, vibrated to proper height and then striped from the mold by lowering the platform. A follower plate came down on top of the meterial in the mold to level and help compact as well as help push the new formed block out of the mold. The steel plate with the block on it was removed from the platform and transported to drying racks. Our brick mold made 20 brick at the time standing on end. The machine companies back then were (in order of capacity) Lith-i-bar, Columbia Machine of Vancover, and Besser. I don't know if any of them still exist.
Support your local Shriners, they have provided FREE medical assistance for over 800,000 kids so far.
06/27/2007 8:21 AM
Thanks for the reply, i got a video of a small machine that i want to build which uses the hydraulic cylinder & motor. This is a video of how the machine works. http://www.youku.com/v_playlist/f273938o9p1.html What do i need to build a machine like this? Thanks, you guys are a great help.
12/14/2007 8:47 AM
Lookhttp://www.ital.com.mx/english/main_equipos.htm
proven machines
06/27/2007 8:37 AM
For most usual small machines
www.industrialjoper.minored.com/
06/27/2007 4:04 PM
You can also use an extrusion process. Extrusion is very cost effective, however, the rheology window on the mix is critical. Basically, use a plug mill and a wire cut for the brick thickness at the extrusion die. You must also know your shrinkage, function of the mix and other oxides used in the formulation.
06/28/2007 5:22 AM
Thanks Ydobon, my budget is $1000 USD, would this be enough? Could you pretty please give me a list of the material that i need to build the extrusion machine so i could do some research, i would really appreciate that! Thanks.
12/14/2007 8:03 AM
Zyhlo,
I stumbled upon on your request for a Brick Making machine construction. I happen to do the same thing right now, still in the designing stage.
Have you built your machine?. l can also be contacted through my email address: fountainbase@yahoo.com
07/13/2008 3:12 AM
Are you still looking or got what you want?? If still in need contact mizun@bol.net.in for assistance.
Best wishes,
Mizun
Register to Reply 15 comments
dovrak (2); DVader1000 (1); Grego (1); JasBond (1); Johnjohn (1); Mizun (1); raimon (2); Ydobon (1); zyhlo (5)
