Previous in Forum: Brick Making Machine?   Next in Forum: Wing Folding Mechanism
NPSM female to NPT male
06/26/2007 10:59 AM
I need to connect a double check quick disconnect to a hose. The QD is 1/2" NPSM female threaded and the hose to pipe is 1/2 NPT male threaded. Using thread sealing compound will this be an acceptable connection? Service is intermitent and will be used to load/ unload lubricating oil with a 100 PSI max pump
Good Answers: 137
Re: NPSM female to NPT male
06/27/2007 4:38 AM
What does NPSM stand for? Is it a thread type? I hadn't heard of it (perhaps it's well-known in US but not here in UK) so I Googled it. Link below says thread sealing compound is not required.
http://www.parker.com/tfd/fittingsolutions/o7fittingsolutions.pdf
Codey
06/27/2007 6:45 AM
why don you make a conector one side NPSM male and the othe NPT female????
06/27/2007 7:50 AM
I am assuming that the NPSM female is a swivel?
In order for this to seal correctly, the 1/2" NPT male fitting should have a 30° internal taper seat (female) for the corresponding NPSM male taper inside the swivel. If it doesn't, it won't seal properly.
Because this is a taper seat seal, no compound is necessary.
Codemaster, this is very similar to a BSPP connection, only NPT threads.
In my many years I have come to a conclusion that one useless man is a shame, two is a law firm, and three or more is a congress. - John Adams
06/27/2007 11:26 AM
NPSM is a parallel thread but it will mate with the NPT thread OK and with thread sealing will easily take 100PSI.
Just make sure you use similar materials
Codemaster (1); dovrak (1); garth (1); mareng (1)
You might be interested in: Air Hose and Air Duct Hose, Hose Crimpers, Hose Reels
