Previous in Forum: Products Manufactured By Gravity Casting   Next in Forum: Temporary Repairs on Process Piping
Difference Between S275JR and S75JR+AR in Steel
06/05/2014 7:27 AM
Dears ,
Any one knows what is the difference between S275JR and S75JR+AR in steel , in terms of abbreviation i know that S275 in EN10025 reflects the properties of steel , AR refers to the " AS rolled " condition , material strength / properties wise ... does it make any difference ?
thanks,
Pathfinder Tags: S275JR and S75JR+AR in steel
Re: Difference Between S275JR and S75JR+AR in Steel
06/05/2014 11:33 PM
I wouldn't think they would have the same spec. As rolled condition is just that, it might be descaled but otherwise it's a piece of steel "hot off the presses." No secondary operations have been performed, the end user of the product usually performs any heat treat or annealing process they require instead of the mill doing it. If you're dealing with a "middle man mill" they probably get the stuff AR and perform their own operations such such as sizing or grinding and perform proprietary treatments. Actually it would be size, treat, grind usually. Our just size and treat. Basically, as rolled material will be all over the place will it's internal crystalline structure. It will have the the correct ratio of elements throughout to meet a standard, that's about all you can count on. Depending on what it will be used for AR can be perfectly acceptable. For example, cutting out work piece supports for a laser or plasma cutter. Use the cheapest crap you can find (machine designer here, hence that example). If you're using for anything structural it would need to be normalized at the very least to give uniform properties throughout. If I recall correctly it's mainly used when ever you are using a heat process to cut and assemble an element. Like welding up custom I or H beams. With AR material you can heat it up to your hearts content, making processes less controlled and faster because you're going to normalize/heat treat/annealing it anyway, so why pay for material that has undergone a process when you require it to go though the same process after you've done whatever you're going to dowith it anyway. Sorry for the large paragraph, tablet really doesn't like the text boxes here. Regards, Steve.
06/06/2014 7:12 AM
thanks steve for your interest and reply ,
actually the reason of the question was that the steel supplier was trying to convince one of my colleagues that the S275JR+AR is better than S275JR mechanical properties wise , some quick research proved what you rightly said above , through various processes for the steel ( As rolled / normalised / thermo mechanically rolled / quenching and tempering ) in the as rolled condition you have to redo some heat treatment to refine the crystallization and the grains sizes,
going through the 2 WTC s ( S275JR / S275JR+AR) it`s found that the 275Jr is higher than +AR by 3 MPa in each figure ( yield / tensile ) , 3 MPa is not the significant difference i know , but for sure the as rolled condition is not better like what the supplier said in this case ...
regards,
Register to Reply 2 comments
