Previous in Forum: Difference Between S275JR and S75JR+AR in Steel   Next in Forum: Differentiating Between Reverse Air and Pulse Jet Baghouses
Temporary Repairs on Process Piping
06/05/2014 2:36 PM
As per API-570, metallic welded sleeve on pipe at low thickness locations is considered as Temporary Repair. What is the engineering reason behind due to which this type of repair can't perform like the original pipe , while the sleeve thickness and fillet weld sizes are calculated as per ASME PCC-2.
Re: Temporary Repairs on Process Piping
06/05/2014 3:41 PM
06/05/2014 3:47 PM
It isn't safe.
Good Answers: 203
06/05/2014 11:17 PM
1) You want the repair to be at least as strong as the original piping.
2) It is more dangerous to have a pipe with a history of leaks and repairs than it is to use new pipe.
3) always replace a previously defective and patched pipe with new pipe as soon as possible.
Good Luck, Old Salt
06/06/2014 6:56 AM
Because you already know that the pipe is getting thin underneath the repair and you don't know where it is going to leak next.
Next time, choose pipe materials that are compatible with your process fluids!
Good moaning!
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
06/06/2014 9:58 AM
You try to patch it, instead of fixing it properly.
It fails.
Someone gets hurt or killed.
Someone gets punished, as in sent to prison.
Is it worth it?
Speak softly and carry a big stick.
06/08/2014 12:40 AM
Thanks to everyone and really appreciate the response, yes agreed this is really a safety concern.It may lead to very high consequences in terms of safety and loss of production for an extended period of time.
What i am thinking the reason of classifying welded pressure metallic sleeves / patches under temporary repair category in API codes (570 & 510). The pipe is originally designed as a thin cylinder as per ASME B31.3 and is more flexible. while putting a metaalic sleeve on thinned pipe will make it a thick cylinder where the flexibility to internal pressure stresses and external loadings will be less compared to original pipe. Moreover, the perimeter wleds joining the sleeve to carrier pipe are less strong to BUTT welds. Therefore, the probability of failure is more than the original pipe.
Do you agree with this???
Register to Reply 6 comments
Crabtree (1); jack of all trades (1); lyn (1); old salt (1); shehzadmr (1); standarded (1)
