Previous in Forum: Looking to Develop our Production Package   Next in Forum: Wire Braiding Methods
15 comments
Welding Time For SS316 vs Inconel Alloy Pipe Welds
06/10/2014 12:30 AM
Dear All,
I am trying to estimate time required for pipe welds of different sizes. Can you please reply with approximaate time required for SS316L vs Inconel alloys of the saame size pipe??
This shall help me to estimate budgetl duration for projects.
Re: Welding time for SS316 vs Inconel alloy pipe welds
06/10/2014 2:43 AM
What is to be included in the calculation - just the melt time or does one include the setting-up and the breaking down time? Are these welds being done in the field or on a bench somewhere? Does the operative have to fetch and mount the pipes or will someone else do this? Are consumables to hand or do they have to be fetched from somewhere or ordered for delivery from somewhere? What is the lead time? What else is there for the operative to do while supplies are arriving? Is there sufficient equipment to carry out this work continuously or will it be intermittent? What observations have been carried out so far and what has the organisation learned from them?
There are rhetorical questions and there is no need to reply to them for the information is of no value here, because without seeing the facility and having a view of its capabilities, the best person to carry this work out is the Original Poster.
06/10/2014 5:50 AM
Kindly include just weld time. My question is aimed at variance or difference for welding time of these two parent materials.
06/10/2014 6:44 AM
Well, if that information is already to hand from experiments indicated in #3 below, then there is little scope for CR4 to add anything further. Good luck with the quest.
<unsubscribes>
06/10/2014 2:48 AM
There is far too much missing to even begin to provide anything likely to be specifically useful.
06/10/2014 5:00 AM
Get some pipe, a welder and a stop watch and time it.
Kindly let us know the answer.
06/10/2014 5:21 AM
Are you using the same welding technique for these materials or is it different?
06/10/2014 5:48 AM
Dear All,
I am going to use same technique for both material.
My question is basically aimed at variance of time between two parent materials SS316 and Inconel.
Welding time for one joint considering fit up and all set up is done for welding.
06/10/2014 10:03 AM
I'm going on the assuming the process is TIG and the Inconel is 625.
Inconel is going to take longer and it takes a little more skill/knowledge than 316.
316 is a delight to weld. It is very clean, the heat stays where you put it due to low thermal conductivity but not so low as to impede decent speed. A novice can learn to run excellent beads with good speed with just a little practice.
625 Inconel is the easiest of the Inconel alloys to weld, but it isn't easy like 316. 625 has very low thermal conductivity, which makes the puddle extremely slow, resistant, almost stubborn. A similar bead in 625 will run longer than in 316, at least 20% longer, maybe more than 50% longer.
But there are other aspects of welding 625 that will take up more time.
625 tends to pull strongly when welding so it typically requires far more and stronger tacks when fitting up. 625 requires more care in purging and backing argon than 316. As well, argon control in the torch is more critical.
Welding 625 creates an oxide layer that resembles the oxide layer that forms on the workpiece when welding aluminum. It is also noticeable in the weld pool but not to the extent it is with aluminum. Time is required to brush off the oxide layer after each pass while it is still easy to remove...let it cool, and it is much more work.
625 will try to crack at the end of a bead, and additional time is required to ramp down, add a little filler and pull reduced pool to the side of the bead.
A little additional time is required to clean up filler rod ends more often and resharpen/replace tungsten with 625 as well.
More care has to be taken in keeping the tungsten close and not letting the filler rod leave the argon blanket as well.
My guess in total would be a good welder experienced and working with 316 can probably complete work in maybe half the time as a good welder experienced and working with 625, but it will depend a lot on the nature of the workpiece and what is required.
Good Answers: 18
06/10/2014 11:25 PM
Generally we calculate it as 1.5 times more than SS welding due to slow progress in inconel tube / pipe welding. Requirement of filler wire is 1.25 times that of SS
sridhar
What we have done for ourselves alone dies with us: while what we have done for other and the society remains and is immortal.
06/11/2014 1:33 AM
Thnks Sridhar for your kind guidance.
06/11/2014 1:35 AM
Awsome details.... It was really knowledge enriching answer..
I guess my aim of question is done with this answer...
Thanks a lot again...
Re: Welding Time For SS316 vs Inconel Alloy Pipe Welds
06/10/2014 8:43 AM
"See # 3 above"
As these are materials that require similar handling for prep and production, I would estimate the variance to be a couple of per cent at maximum. The main variable here is the welder's skill... that will vary a great deal, and is your main problem. A welder with 20 years experience could reduce the time by more than 50%. Likewise quality weld prep.
06/10/2014 8:46 AM
Thank you very much for ur reply...
06/11/2014 10:42 AM
If there are mechanical contractors/ process piping contractors in your area, I would suggest that you inquire about their shop weld productivity. There is also a manual available developed and published by the MCAA (Mechanical Contractors Association of America that has a wealth of information regarding welding productivity of all metals used in piping. You have to be a member to obtain access for either a hard copy or web access. MCAA labor productivity uses a 1.0 factor which is the "benchmark" and then a shop would measure their historical productivity and use their experienced factor which could be higher or lower than a 1.0. This sounds like it is a shop environment so fire watch, welder pimp and other labor cost can be disregarded. Field welds are a whole different animal.
06/15/2014 12:29 AM
Make sure that, your company management has good relationship with client's Welding inspector.Any issues with inspector will affect weld production time.
Register to Reply 15 comments
geraldpaxton (1); IdeaSmith (1); lyn (1); PWSlack (2); sanweld (1); shailesh411 (5); SRIDHAR (1); Steve Batey (1); truth is not a compromise (2)
