Previous in Forum: Power Swing   Next in Forum: Control Magnetron Power Using a Variac and 2 MOTs
VR3 Regulator Problem
06/12/2014 5:28 PM
Hi All, I have a problem in 300KVA caterpillar PMG genset with VR3 Regulator,if i start the genset it will burns the fuses in the VR3,two fuses for three phase sensing and two fuses for the PM field winding. the PMG field has no leakage between winding to ground same as exciter field.what is the probable cause of fuses to burn?
Re: VR3 REGULATOR PROBLEM
06/12/2014 5:45 PM
This may, or may not, help.
Electric motors, generators & controls engineering - Caterpillar ...
When all else fails, call "the man".
Good Answers: 445
06/12/2014 6:42 PM
Fuses "burn" for a reason, and the reason is too much current passing through them. If all of them are blowing at the same time then your only option is to call the manufacturer or the place that sold it to you.
Some where you have a combination of faulty/improper grounding and a phase to ground short circuit; a deadly combination to the uninitiated. Do not operate that system until someone who knows what they are doing is leading the effort.
06/13/2014 10:04 AM
I'll take a WAG that the OP does not have any way to measure the current going through the fuses before they open. A trained eye can sometimes tell by looking at the remains of a glass tube fuse if just over or dramatically over current condition happened that caused them to blow.
Register to Reply 3 comments
lyn (1); RAMConsult (1); redfred (1)
