Previous in Forum: GE Multilin MIF Relay Failure   Next in Forum: VR3 Regulator Problem
Power Swing
06/12/2014 5:38 AM
During power swing how Distance protection relay will see and what changes will appear in voltage and current at distance relay protection.
Good Answers: 445
Re: Power Swing
06/12/2014 9:36 AM
I suggest that you get a copy of GE's Art & Science of Protective Relaying, there's 16 pages on distance relays and how they work. Google and you will find it for free.
Good Answers: 804
Re: Power Swing
06/12/2014 12:17 PM
When I saw "power swing" I thought it would be about this:
Click image for video
Re: Power Swing
06/13/2014 2:45 PM
This guy is installing a power swing of his own...with red ropes
...I think he needs a distance protection relay...
common knowledge...less common than common sense
Re: Power Swing
06/13/2014 4:39 PM
http://www.pes-psrc.org/Reports/Power%20Swing%20and%20OOS%20Considerations%20on%20Transmission%20Lines%20F..pdf http://iie.fing.edu.uy/investigacion/grupos/ecsep/presentaciones/Presentación%20paper%20154.pdf These links may give you some idea about that. Not complicated setting on Micom Relays... Switch on and off.. Just this. It isn't necessary to chew.
Either exist as you are or be as you look. Rumi
Re: Power Swing
06/13/2014 4:40 PM
Re: Power Swing
03/04/2017 2:35 PM
POWER SWING:
...Depending on the severity of the disturbance and the actions of power system controls, the system may remain stable and return to a new equilibrium state experiencing what is referred to as a stable power swing. Severe system disturbances, on the other hand, could cause large separation of generator rotor angles, large swings of power flows, large fluctuations of voltages and currents, and eventual loss of synchronism between groups of generators or between neighboring utility systems....
Power System returned normal state at last without blackout in this sample.
Register to Reply 6 comments
engilis (3); JRaef (1); RAMConsult (1); The.Tinkerer (1)
