I have a tank that is capable of 3000PSI. Would it be possible to outfit it with a Schrader Valve so that the output is around 80PSI? I'd like to use the higher PSI to store more air, but then use it at 80PSI ... am I stuck having to buy a reg?
Yes, your stuck buying a regulator. Once you open the schrader, your exposing the entire 3000psi, but at that pressure, that said, I'm betting you couldn't get the schrader to open.
look under compressed gas valves. There are some listings for general purposes which are in expensive.
