Previous in Forum: Earth Gravity   Next in Forum: Where can I view/buy pin valves?
car struggling 2 start
06/28/2007 5:45 AM
hi
my car struggles 2 start i have to crank or turn the engine for about 10 seconds and then it catches on slowly. any help please. ive been everywhere
Re: car struggling 2 start
06/28/2007 7:40 AM
Petrol?
Diesel?
LPG?
Electric?
Good Answers: 40
06/28/2007 9:50 AM
It could be a number of things. Need more symptoms.
Smell of fuel? Color of exhaust? rough idle? loss of power?
Possibilities;
- Dirty Air filter (replace)
- Fuel filter clogged (replace)
- Spark plugs fouled or need to be replaced (replace and gap)
- Spark plug wires defective (replace)
- general build up of sludge etc in motor (engine flush)
- Injectors fouled or carburetor problems depending on vehicle type (Have them cleaned)
- weak or damaged cell in Battery (replace, Get one with more power. The one that comes with the vehicle is usually the minimum)
- defective starter (replace)
- Defective alternator (replace)
- Vacuum leak (repair)
- Poor compression due to leaky gasket (overhaul)
- Dirty or damaged valve seats (overhaul)
Good Answers: 40
06/28/2007 9:58 AM
There was also a few vehicles (such as the Plymouth Voyager) that had problems with crud building up on the butterfly valve in the intake manifold. This crud would restrict air flow.
If this is the case, remove the large hose from the air filter, reach in with a rag and cleaning solutions and simply clean both sides of the butterfly valve. This may need to be done every couple of months.
06/29/2007 3:40 AM
.........so the script goes,
Seagoon: "My husband and I have great pleasure in starting this Goon Show No.161!"
Grams: sound of prolonged churning from lorry engine.
Seagoon: <clears throat> "My husband and I have great pleasure in starting this Goon Show No.161!"
Seagoon: <clears throat> "My husband and I are having great difficulty in starting this Goon Show No.161!"
(with apologies to the late Spike Milligna, the well-known typing error)
Engineering Fields - Manufacturing Engineering - United Kingdom - Member - Get things done!
06/29/2007 4:48 AM
Would you like a gorilla to go with that?
'The truth is out there' The lies are in your head.
Anonymous Poster (1); PlbMak (1); PWSlack (1); techno (2)
