Previous in Forum: Girth Gear and Pinion Damage   Next in Forum: Piston Pump
Removing Corrosion
06/18/2014 8:55 AM
Dears ,
can we clean inside of CS(A 516) tank with water ? if cleans with water what are the problems rises , any corrsion issues arises? please suggest best cleaning procedures to remove corrosion formed at tanks inside shell
thanks ,
Re: Removing Corrosion
06/18/2014 9:54 AM
What's in the tank now, Mildred, and why is there a perceived need to clean it?
Good moaning!
Good Answers: 26
06/18/2014 12:33 PM
Muratic acid. Just give a good rinse with water. I have even used vinegar on Cs plates, problem is the plates come out smelling like pickles.
06/18/2014 3:08 PM
"... The usual methods for rust removal from carbon steel include abrasive blasting (wet or dry), brushing, acid pickling, salt bath descaling, alkaline descaling, and acid cleaning. The selection of the rust removal method depends on many factors as well including the thickness of rust, the composition of the metal, allowable metal loss, surface finish tolerances, available equipment, and cost. If moist air is the cause of your problem, you might consider purging the tanks with dry nitrogen and using a nitrogen conservation vent. This will permit the tanks to "breathe" while preventing the ingress of moist air. If you are trying to detect small rust deposits, the easiest NDT test may be visual testing. This can be done by the naked eye via periodic internal inspections of the pressure vessels themselves or with the aid of cameras, borescopes, etc. If significant areas of rust are constantly being formed and flaking off, ultrasonic thickness testing may be useful."
http://www.chemicalprocessing.com/experts/corrosion/show/524/
Anonymous Poster #2
06/18/2014 3:50 PM
I'd stay anonymous - and don't answer any questions.
Good Answers: 109
06/18/2014 8:37 PM
Wire brush!
Not enough information to make any other comment!
Good Answers: 25
06/19/2014 6:41 AM
You can try high pressure water jet pumps specially made for tank cleaning.
06/23/2014 9:24 AM
i think, water jet is not correct ,it gives more corrosion . water jet cant remove crrosion also
Anonymous Poster (2); Crabtree (1); IdeaSmith (1); SolarEagle (1); suresh sharma (1); texasron (1)
