Previous in Forum: Metal Bonding Paste   Next in Forum: Scale-up Batch Chemical Reactors
8 comments
NACE MR 0103 - Material
06/20/2014 1:55 AM
The material requirment is SA516 gr. 70 + NACE MR 0103 (carbon steel)
please let me know the special requirement in material as per NACE MR-0103 i.e. criteria related to carbon content percentage, hardness requirement, and specific alloying material contain percentage.
if we use Chemistry Control plate instead of NACE MR-0103 same will acceptable or not?
Pathfinder Tags: NACE MR0103
Re: NACE MR 0103 - Material
06/20/2014 7:28 AM
In what context?
As far as acceptability is concerned, the local standard applicable to the project will determine this. What is the standard?
06/20/2014 7:37 AM
it is required for FLARE STACK.
in project standard for carbon steel carbon contain shall be less than 0.23% and carbon eq. will be 0.43%.
In NACE MR-0103 code carbon contain shown as less than 2% but i have never seen that much qty. of carbon in materials like 516 gr.70
06/20/2014 7:39 AM
Then it would be compliant, self-evidently.
Good Answers: 104
06/20/2014 8:28 AM
If the material specification includes MR-0103, then nothing "instead of NACE MR-0103" is compliant.
Good Answers: 26
06/20/2014 2:21 PM
From slabs, for T between .3125 to 1.5"(plate)
C is .18 to .22
From slabs, for T up to 3.00"(plate)
C is .23 to .27
06/21/2014 1:15 AM
where it is exactly stated.
06/21/2014 7:19 PM
Out in a Bowt
Good Answers: 34
06/28/2014 8:02 AM
There are several major differences between MR0103 and MR0175/ISO 15156:
_ The refinery standard guidelines for determining whether an environment is "sour" are
quite different from the sour environment definitions provided in previous and current
versions of MR0175
_ The refinery standard does not include environmental restrictions on materials.
_ Materials and/or material conditions are included in MR0103 that are not listed in
MR0175/ISO 15156.
_ Materials and/or material conditions are included in previous and/or current versions of
MR0175/ISO 15156 that are not listed in MR0103.
_ Because welding is prevalent in refinery piping and equipment, MR0103 places extra
emphasis on welding controls in several material groups, most notably the carbon steels.
Applicability of MR0103. Both MR0175 and MR0103 include sections that describe applicability
of each of the standards. Both describe material factors and environmental factors, and provide
guidelines to the user on how the standard should be applied. Note that both standards require
the user to specify whether the environmental conditions are such that the material requirements
of the standard should be applied.
One of the key differences between the MR0175 and MR0103 standards lies in the the environmental conditions under which SSC is likely to occur. MR0103 covers a
broader range of sour environment conditions experienced in downstream process units. These
are based on:
_ User's plant experience and practices
_ Existing NACE and industry recommended practices and reports (i.e., NACE RP0296,3
8X194,4 8X294,5 API Publication 5816)
_ A fundamental understanding of atomic hydrogen generation in the sour service corrosion
reaction and the subsequent rate of hydrogen flux into the process-contacted steel, i.e.,
combined effects of pH, H2S and HCN.
Register to Reply 8 comments
bigg (1); PWSlack (2); snowboy (1); texasron (1); vp_007 (2); Whitephone (1)
