Previous in Forum: DNA-Embedded Threads   Next in Forum: Standard for hose fittings
Rubberised drive wheel for linishing machine
06/29/2007 12:59 PM
Hi all,
I need a drive wheel for a linishing machine that I am building to sand down rusty old metal parts ex. chrome car bumpers. I have all the parts but cannot find a drive wheel to fit on the motor to turn the sanding belt. This drive wheel must have soft rubber on the outside. I need soft rubber on the outside so the belt shapes on to the different radii / curves of the part being sanded. The drive wheel should be about 20 or 22 cm diam, 5 or 6 cm wide, and have soft rubber for the about 2cm on the outside.
Can any one suggest from where I can buy this wheel?
Thanks Albert
Good Answers: 117
Re: Rubberised drive wheel for linishing machine
06/29/2007 1:56 PM
I won't go to the trouble of googling sources for you (you can do THAT yourself) but I might venture to comment on the type of wheel you should be looking for. I purchased a wheel from Eastwood (www.eastwood.com) that expands to hold a sanding belt in place. It is about the size you are looking for. I have one, and love it. For industrial jobs, you might think about loose compound with sisal buffs, or just use hard sewn or sisal buffs, preferably double wide with greaseless compound. Its available in 80 grit down to 320 grit, then tripoli on flannel buffs, then of course, finish with white rough on a loose flannel buff.
questions? email me at stag@cyberus.ca
Good Answers: 266
07/02/2007 4:21 PM
Make the drive roller and have it covered with rubber of a durometer of your choice.
07/05/2007 4:54 PM
Good quality lawn mowers have just the right wheels. Offset flat tread @ 90 deg. works well even for direct sanding against the wheel. different dia wheels will give variety of belt speeds for different materials. Good luck. Bushdriver. South Africa.
Good Answers: 19
07/06/2007 4:58 PM
In college shop we made a bench mount belt-sander. Drive wheel was fabricated from an aluminum wheel blank machined to required OD and shaft bore (everyone had salvage motors so shaft sizes varied all over the place). Then we glued 3 or 4 plys of inner tube. That was over 25 years ago, and the sander still works since it is very occasionally used.
Register to Reply 4 comments
Anonymous Poster (1); ozzb (1); Ried (1); Yusef1 (1)
You might be interested in: Diamond Tools and Wheel Dressers, Rubber Tubing
