Previous in Forum: Carbon Brushes   Next in Forum: Off Mode
12 comments
Pipe Stress
06/22/2014 2:02 PM
Greetings to all Can someone guide me, I would appreciate advance
I am currently checking stress on a section of pipe to be replaced
the conditions are:
1.      existing pipe: API 5L Gr X65, thickness 0.625¨, ca: 0.0625 ¨
2.       purchased by the client pipe to be replaced: API 5L Gr X65, thickness 0.625 ¨, 206 bar hydrostatic test
Design Factor: 0.72 y ASME B31.4
If         thickness is 0.5625¨, P: 2925 psi
SH may be equal to the allowable stress? (56800 psi). As you can interpret this?
The hydrostatic pressure test in field must be less than the hydrostatic pressure on ground? ) in this section no fittings or valves?
thank
Re: help please!
06/22/2014 2:25 PM
Replace the tired pipe with new stuff to the same specification, and you can't go wrong, Mildred!
Good moaning!
Re: help please!
06/22/2014 2:37 PM
Why not ask your ME?
Re: Help Please!
06/22/2014 4:32 PM
The allowable stress cannot possibly that high. You are misreading some numbers, or worse yet, concepts.
Re: Help Please!
06/22/2014 4:42 PM
Hey, it's 3,787 bar.
No wonder the guy needs help, lots of help.
Re: Help Please!
06/22/2014 4:57 PM
You are confusing pressure (of contents within the pipe interior) with stress (within the pipe wall). The OP is confusing allowable stress with ultimate (or yield) stress, depending on which is used in his local code.
Re: Help Please!
06/22/2014 5:07 PM
That's why I don't do pipe. Ever.
I also never do two shows a nite. Beetlejuice
Good Answers: 109
Re: Pipe Stress
06/22/2014 9:32 PM
The question is not clear! What do you need to know?
Did you mean to ask if you need to include fittings or valves in the test section?
I am let to believe that there would be some fittings - the pressure test fittings - that would be exposed to the test pressure. Anyway everything in the systems needs to meet the system specs.
Rephrase your questions and come out of the anonymos hiding and I am sure somebody can guide you in the right direction!
Re: Pipe Stress
06/22/2014 11:08 PM
Your pipe supplier can give you the allowable stress for the grade of pipe you intend to purchase. The stress you quoted is way higher than I would expect. Also you failed to mention the pipe diameter which is critical in calculating the allowable pressure. Recheck your calculations and good luck.
Good Answers: 27
Re: Pipe Stress
06/23/2014 8:03 AM
What was the reason why the pipe is being replaced to anyway? Knowing this will point you to do the proper analysis..
vsar
Re: Pipe Stress
06/23/2014 11:41 AM
thank all for your comments!!
rearranging the question
The conditions are:
1.       existing pipe: OD 18¨, API 5L Gr X65, thickness 0.625¨, ca: 0.0625 ¨
2.       purchased by the client pipe to be replaced: OD 18¨API 5L Gr X65, thickness 0.625 ¨, 206 bar hydrostatic test
3.       Design Factor: 0.72
4.       ASME B31.4
The replacement of the pipe is in the crossing of a river, because the tube is observed. It's been 27 years since it was built. The hydrologic studies indicate that the pipe must be buried 5 m from the level of the river scour
The client wants to validate the specifications  and stress of the pipeline, to validate if the same material and thickness? hence the confusion
I think I can verify is the buoyancy and verify if the tube during construction is able to withstand loads the weight of the earth and the passage of heavy machinery. I'm right? Is there anything else I can do?
When I calculate the Sh get 46,800 psi.
When I determine Sa also get 46,800 psi, is this correct? I'm doing wrong?
Thanks in advance for your feedback
So sorry for my poor English
Re: Pipe Stress
06/23/2014 3:18 PM
Using the formula for
Straight Pipe under internal pressure from 304.1.2
P = (2St/D)xE
where S = 46800
t = 0.625
D = 18
E = 1
Design Factor = 0.72
I get an allowable internal pressure of 2340 psig.
It is all straight forward except the yield stress of S = 46800. This has the largest effect on allowable pressure. Be absolutely certain of the allowable stress you are assuming.
You must also check structural factors such as the span between supports and other physical parameters.
Re: Pipe Stress
06/23/2014 4:44 PM
thank Mr Dave
the material is API 5L GrX65, then:S=0.72x65000=46.800 psi
According to B31.4, P=2925 psi. My question is if I should calculate hoop stress? when I calculate the hoop stress also is 46,800 psi. that's one of my concerns is that I am doing the right thing?
other physical parameters, can be more specific?
thanks
Crabtree (1); Davesets (2); IdeaSmith (1); lyn (3); pipelinevzla (2); Tornado (2); vsar (1)
