Material grinding process motor through reducer rotating drive disc, the material falls from the cement ball mill under the central entrance and exit, under the action of centrifugal force to the disc edge by the roller to move and the crushing, grinding out lap after the material was speed up the flow to and vertical roller mill to rent in eastern cape with one of the separator, after the meal by the separator back to the mill, the re-grinding; powder while grinding out with air, dust collection equipment in the system to collect down, that is, products . Established through the high-pressure grinding mill for sale in website in the pneumatic conveying of materials, a larger air flow rate, which can use waste heat of gas, at the same time dry grinding operations.
The cause about three-ring micro powder mill for calcium carbonate low investment costs is specificly as follows:
Firstly, as you already know, the trapezium mill in Chennai is a set of crushing, drying, grinding and grading conveyor together, so the entire system of the raymond mill is very simple and the layout is compact enough.
Secondly, compared with ball mill, the area on the ground of vertical mill is about its 50 percent and you don't need something to cover the grinder machine . It's unnecessary to put the grinder mill in a room. Here you can see that the running costs of vertical mill is much lower than ball mill which will significantly reduce our investment.
Apart from above factors, vertical mill can also bring two apparent superiorities:
The first is high grinding efficiency. When vertical mill runs, the roller directly mills on the ring. While traditional grinder machine ------ ball mill still adopts some coarse working principle, the vertical mill can save engery about 30-40% with some new technologies.
What's more, the roller of the grinder machine is a certain distance away from the millstone in the running, and some high-quality materials have been used to make the roller and plate strond enough. All these ensure less wear and longer life for our grinder machine.
Another point is that during the running of vertical mill, hot air will be direct in touch with material when we can get different humidity materials just by changing the temperature of hot air. There is no doubt that we will save a great amount of engery.
