Previous in Forum: Does the Inverter Type Split AC Energy Efficiently?   Next in Forum: Parent Asset in CMMS System
International Code for Depth of Buried Cable in Different Voltage Level HV & LV
06/25/2014 3:16 AM
Please help by providing the specific code NEC or IEC or IEE to get the guidance on the buried cable depth at different voltage levels and their respective clearance.
Good Answers: 181
Re: International code for depth of buried cable in different voltage level HV & LV
06/25/2014 3:47 AM
Has Google stopped working?
06/25/2014 9:11 AM
Google makes you think.
Register to Reply Off Topic (Score 8)
Good Answers: 266
Re: International Code for Depth of Buried Cable in Different Voltage Level HV & LV
06/25/2014 9:55 AM
06/26/2014 12:21 PM
IEEE, NESC, Section 35 Direct Buried Cable, Rule 353 Deliberate Separations - Equal to or Greater than 300 mm (12 in) From Underground Structures or Cables and Rule 354 Random Separation - Separation Less Than 300 mm (12 in) From Underground Structures or Other Cables.
See burial depths in Table 352-1.
http://www.techstreet.com/ieee/products/1789027
Good luck with your quest.
06/27/2014 6:53 AM
NEC or IEC or IEE? Why not local?
10/22/2014 5:06 AM
Because client is asking for internationally accepted code..it is well known that several countries has their different practise.but it is not being asked here.
Register to Reply 6 comments
Blackpaper (1); Brave Sir Robin (1); lyn (1); ozzb (1); saraswata1981 (1); TonyS (1)
