I want to install ug-fed irrigation (sprinklers), area lighting on standard (120VAC), and surveilance camera on my grounds. Have dug trench and laid in (in addition to drain) one Sched-40 PVC (for water under pressure), and two electric conduits--preparing next to hook them togethere and back fill. In one electric conduit will be pulled three wires for the AC lighting. In the other I want to run (both):
- wires to power the 24VDC sprinkler zone valve(s) (these will operate 1 x 1/2-hr/day max), and
- video and 1-channel audio signal wires for the camera.
Question: Respecting 2., any problems with this wire routing? If so, what? And is there a preventative?
Thank you.
Posted in General, meaning C&E and/or EE.
