Previous in Forum: Protection Relay Testing   Next in Forum: A Few Questions About RCDs
Negative Sequence Current
06/26/2014 1:03 PM
Is there any direct or indirect relation among " Negative sequence current,harmonic distortion and Leading PF of a power system ?? Please tell me.
Re: NEGATIVE SEQUENCE CURRENT
06/26/2014 1:43 PM
How many points is this problem worth and when is it due?
Good Answers: 445
06/26/2014 2:35 PM
Please tell us what you have researched the answer to be then we will all be in a better position to discuss.
Re: Negative Sequence Current
06/26/2014 6:07 PM
Do you understand what each of these term means, independently?
Surely, you must have some thoughts on this, yes?
If you can define them for us, we will help you find any relations, indirectly.
06/26/2014 10:45 PM
Negative sequence is negative sequence - and you know all about it . . . ?
Harmonic distortion is harmonic distortion - and you about it as well . . .
And leading power factor is leading power factor . . .
It is possible to obtain all of the above at the same time when you have a system fault or a non-linear load.
06/27/2014 12:34 AM
If I understand things correctly-
Power factor is a load quality and not the source.
Again negative sequence is for unbalance on load side not in source.
Harmonics is a source quality and at times generaatyed due to load parameters also.
Harmonics distirt the things and generates heat and noise so power is lost and power factor starts lagging.
Let us discuss the practical issues not the classroom.
06/27/2014 12:48 AM
If you remove the load, . . and find supply in good condition, . . . then problem is in the load.
If there is no change in the supply after removing load - then problem is in the supply.
The supply may well have negative sequence for a variety of reasons.
Harmonic distortion has little to do with power factor.
Register to Reply 6 comments
Anonymous Poster (1); lyn (1); M.R.Iyengar (1); olehwi (2); RAMConsult (1)
