Previous in Forum: 89 Century Fuel Pump Help!   Next in Forum: Wiring Diagram
9 comments
1979 KZ1000 Clutch Problem
07/07/2014 10:36 AM
I have a 1979 KZ1000 and it been running fine until yesterday. I fired it up without a problem and pulled in the clutch handle and put it in gear and that killed it. It was as if I had not even pulled in the clutch. I still have the normal clutch tension and I have checked the clutch cable and it looks good. Any help would be greatly appreciated!
Re: 1979 KZ1000 Clutch poblem
07/07/2014 11:09 AM
This is pure speculation on my part, I had a Kawasaki in the late 70's and never had a problem.
You may have a stuck disk. If I remember, these clutches are multi-disk.
Try rocking it back and fourth in first gear.
07/08/2014 2:44 AM
He should also hold the clutch lever pulled in when he follows your otherwise good advice!!!
07/07/2014 12:07 PM
Nice bike....I would refer to the manual to check/adjust clutch mechanism....and here's a good forum link...
http://kzrider.com/forum/2-engine/252551-need-help-with-kz1000-police-special-clutch-issue
Re: 1979 KZ1000 Clutch Problem
07/07/2014 10:37 PM
I too have had 70's Kawasakis and the most likely cause of your problem is the multi disc clutch. Fibre discs are stuck to the metal discs. If I remember correctly there are seven fibre discs and seven metal discs in the clutch basket. This used to happen to me after a long ride with a fair bit of stop and go traffic. My solution was a bit more drastic than rocking it back and forth with the engine off. I used to push the bike up to the back bumper of my car, rev the motor up to a couple thousand rpm and put it in gear. It always came loose. Not sure I would use that method today. Probably safer to rock it in first gear with the motor off and the clutch lever pulled in to the handle bar. One thing I always did was once I got it loose, I would change oil and the filter just in case I had gotten the oil too hot and it had started to breakdown.
07/08/2014 9:44 AM
If it were me that owned the bike, i would just change out the clutch plates myself. it is rather easy.
drain oil. remove clutch cable. remove clutch plate cover. remove clutch plate basket cover. remove and replace plates in same order as removed. reuse metal discs.
put clutch plate basket cover back on. get new gasket for clutch plate cover. put a little rtv on gasket (some will disagree). re-install plate, attach clutch cable. re-fill with correct oil. adjust clutch cable. have fun riding that beast!
will take approx. 1 hr. to do this job.
07/07/2014 11:01 PM
If the above suggestions regarding dragging or stuck disks or cable adjustment do not help, you may have a seized needle bearing on the backside of the clutch basket that in effect ties the basket to the input shaft on the transmission.
See item 2 in the diagram below.
Good luck with your quest.
07/07/2014 11:05 PM
By the way, nice bike!
07/14/2014 11:03 AM
Thanks for everybody's help! Due to triple diget weather I did not get back to this project until this weekend. I changed the oil and filter as it was due anyway and still had a problem. I lined up the frount end to the shop wall pulled in the clutch and it keep stalling before engaging. Then being a grduate of makedo U I next got 2 rolling pins (bakery type) mounted on a 2x4 stand with u-bolts so they would spin. Then I secured with long 2x4s to shop wall. I lifted the bike so the rear wheel was on the rollers and fired it up, pulled in the clutch and had the wife push the shift lever down. The rear wheel stared spinning and I released the cluch handle as I tried to hold her in place. (The bike not the wife) and then all hell broke loose as the rear tire hit the side of the 2x4 stand of the roller pins stand shooting the home made contraption across the shop & the bike stalled. Fired her back up pulled in the clutch and it worked fine!! Thanks to all of you for your help. Hope I can return the favor sometime!
07/14/2014 11:15 AM
Good to hear she broke free.
Register to Reply 9 comments
Andy Germany (1); Brave Sir Robin (2); lyn (2); Robert F.Laurin (1); setlock77 (1); SolarEagle (1); writer (1)
