Previous in Forum: Engine Oil Service Grade   Next in Forum: Measuring the Force to Shear a Pin
Mechanical Tests
07/13/2014 2:27 PM
Hello
Please, could hou help me to find a reasoned response. I have a pendulum impact test manufactured according to ISO standard ISO 148 -2 (radius 2 mm).
According to ASME codes, is that Ican apply the ISO 148-1
Best regards
Re: mechanical tests
07/13/2014 2:38 PM
A reasoned response to what?
You have not made a case to deviate, if that's what you want to do.
"I have a pendulum impact test manufactured according to ISO standard" does this mean you have purchased an impact tester? Or are you supposed to perform the test and want to change the rules?
What does the ASME code have to say on the subject?
Or, do you want someone to give you a free opinion?
If so, I'll be glad to render such an opinion.
07/14/2014 2:22 AM
Hello
Thank you for your reply.
I'm sorry, I'm new to this site.
I expect from you a free opinion.
In Tunisia, we apply the ASME codes in the field of oïl and gas. There only Charpy Pendulum impact test according to ISO. ( ISO 148 and ASTM E23 are different to the radiud of the knife).
IS The ASME code section VIII division 1 for example accept the results repaired in accordance with ISO 148-1.
Best regards
07/13/2014 7:57 PM
You can use those parts of 1 that are in compliance with 2....but 2 supersedes and thereby cancels 1...
Register to Reply 3 comments
lyn (1); mohsenlassoued (1); SolarEagle (1)
