Previous in Forum: Crossing of Plumbing and Electric Services   Next in Forum: I Wonder If this Guy Has Posted Here?
Heater Cutoff By Digital Timer and Differential Pressure Switch
07/14/2014 11:50 AM
I have a m/c with two heaters and a differential pressure switch and digital timer to cutoff the heater supply.
want to connect those to a 4 pole contactor with two auxillary connections.
needed circuit connections and wiring diagrams.
my idea is to connect the digital timer to input of contactor and pressure switch to auxillary connection of contactor.
please guide me with ur suggestions.....
Re: Heater Cutoff By Digital Timer and Differential Pressure Switch
07/14/2014 2:37 PM
Start by writing down, in English, everything you want this contraption to do. Design the circuit afterwards, Mildred.
Good moaning!
07/14/2014 8:46 PM
Perhaps it would help if you defined you acronym m/c. https://www.google.com/search?sourceid=navclient&aq=hts&oq=m%2fc&ie=UTF-8&rlz=1T4GGHP_enUS517US517&q=m%2fc&gs_l=hp..3.0l5.0.0.0.4709...........0.znvHh5I8OZs
Is it a MotorCycle, or a Master of Ceremonies, with 2 heaters and a differential pressure switch?
07/15/2014 8:46 AM
vertical Autoclave for operation theatre
Register to Reply 3 comments
balakolli001 (1); Crabtree (1); Kilowatt0 (1)
