Previous in Forum: Stabilizer for Air Conditioners   Next in Forum: M/G Set vs Rotary Converter
17 comments
Leakage Current
07/18/2014 10:00 AM
Hi All,
We are facing a strange problem where in even though we are not using any electricity, the meter shows units consumption. To isolate the problem, we switched off all the MCB's and found that no units is consumed. But when we switch on all the MCB and still dont use any electricity, still the meter shows the consumption units with MCB's on. ( ex: in 30 mins showing 2 units consumption even though no load, but MCB's ON). can anyone guide us how to isolate this leakage current.
best regards,
venkata
Good Answers: 50
Re: Leakage current
07/18/2014 10:17 AM
What are the loads being powered? Are there any EMI filters wired into these that are active when the CBs are closed?
If you have EMI filters, it's possible a capacitor is leaking, and drawing more then the reactive power it normally would.
ignator -
Good Answers: 804
Re: Leakage current
07/18/2014 10:18 AM
Follow me here, this is very complex. Turn the MCBs on one at a time, observing the current. When you find one in which current flows, start tracing the wire that is connected to the load side of it. Whenever that wire connects to a device, lift that wire off of the terminal and see if the current flow ceases. If it does, look at the device itself as a consumer, or if it is only a switch, repeat the process starting from the other side of that switch, following every wire in that circuit until you find it. It's there.
Here is what you will likely find by the way. It will be a transformer, a power supply (which will have a transformer inside), an resistor of some sort, an RC snubber (which has a resistor inside), a pilot light (another resistor) or possibly a high resistance ground fault or short circuit.
Re: Leakage current
07/18/2014 10:47 AM
GA. Even the GFI contain monitoring electronics that consume tiny amounts. For OP to have measurable results, most likely it's a transformer, as you say. There are many " vampire " circuits these days, the only way to track them down is load shedding. Any equipment " off " but on standby could have tiny drains. GA.
Good Answers: 69
Re: Leakage current
07/18/2014 5:33 PM
Good answer, and a classroom classic as well, a bump on the head followed by an enlightening lesson.
Re: Leakage current
07/18/2014 10:38 AM
Is there no one on your staff who has even a rudimentary understanding of electricity?
Just asking.
Good Answers: 69
Re: Leakage current
07/18/2014 5:26 PM
They surely have, but they all are too dazed by the miriads of new devices which turn a light ON, to indicate that the device is OFF.
Re: Leakage Current
07/18/2014 3:51 PM
Open the breaker box, get a clamp on ammeter, and check the current for each breaker.
Re: Leakage Current
07/19/2014 10:06 AM
If you have any buried (underground) wiring, it is possible there is a cut in the insulation.The cut does not have to be very large,just a minor nick will do it.The surrounding ground will absorb the heat.This frequently occurs when wires are not buried deep enough,or if there is very rough back fill over the wire,such as crushed brick,etc.
Isolate the circuit as previously described to determine the particular one of interest.
Good Answers: 27
Re: Leakage Current
07/19/2014 10:22 AM
You have electric clocks, door bell, clock radio, cable box, and other electronic appliances like TV, cellphone chargers, etc. that have built-in timers that are always ON and consuming power even if their power switches are on OFF positon!
vsar
Re: Leakage Current
07/19/2014 11:00 AM
Even supplying power on long cables, uses a small amount of power, even though nothing is switched on at the end of them.
The longer the cables, the greater the effects....
Its best to activate circuits with long cables only when actually needed....but also remember, the effects are "cumulative" and a dozen short cable runs will add up to the same power loss as a longer single cable run.....roughly speaking.
Re: Leakage Current
07/19/2014 1:58 PM
How so?Please explain,aside from capacitive charging,which is very negligible,and not a constant drain.I have seen capacitive effects on long communication lines, but never on normal neighborhood occupancy power.
Re: Leakage Current
07/19/2014 3:01 PM
Has the OP stated ".....normal neighborhood occupancy power."
I never saw it. Please be so kind as to mention which post that was?
My impression was that it was industrial, not domestic....
The losses from power station lines can be 5-6%......the national average is in that range, partly resistive of course.....remember. the lower the voltage, the higher the losses....
We are working here with incomplete infos.....remember G.I.G.O?
Now are you surprised? I won't be, either way.....
Re: Leakage Current
07/19/2014 3:41 PM
Where did he mention "power stations" or long distance power transmission,or a national or regional problem?
He mentioned MCB's which are normally indicative of low voltage conditions and a meter,not meters,(Which would consist of 3 meters in industrial applications:
1ea KVa meter, 1ea Kvar meter, And 1ea Demand meter.)
Would the OP please clarify which type system he is referring too, to avoid ambiguity in answers?
Re: Leakage Current
07/20/2014 10:38 AM
I note he says "we" and not "I", which makes me think of a firm rather than a family.....not that its truly indicative either way.....just a thought!!
Re: Leakage Current
07/20/2014 4:07 PM
I am not going to play this game of semantics with you.I will wait for the OP to clarify his question.....or not.
Re: Leakage Current
07/20/2014 5:43 PM
Why not? Its the only best game in Town!!
Location: I live in USA, Colorado in the houses of 7 Summits
Re: Leakage Current
07/26/2014 3:48 AM
Leakage current is the current that flows through out the protective ground conductor through ground. There are types of leakage current, these are AC leakage, DC leakage etc. To isolate the leakage current, the measurement of leakage current is one of the most important tests in electrical current, to isolate the leakage current by supplying voltage current normally, apply the DUT power source to isolate the leakage current.
Register to Reply 17 comments
Andy Germany (4); HiTekRedNek (4); ignator (1); JRaef (1); LongintheTooth (1); lyn (1); Rixter (1); ShawnHoppe (1); vsar (1); Yahlasit (2)
