Previous in Forum: Problem In CCPD   Next in Forum: 50/60Hz Frequency
Current Transformer
07/21/2014 1:31 PM
i want to use to digital energy meter (at different locations) with one set of ct's how to connect ct's? series or parallel ? what is connection ?
Gaurav
Re: current transformer
07/21/2014 1:46 PM
Re: Current Transformer
07/21/2014 3:40 PM
Did you talk to the seller before committing?
Did you read the instructions that came with it?
Good moaning!
Good Answers: 181
07/21/2014 3:52 PM
Just when you thought it couldn't get any worse,
It does.
07/21/2014 5:01 PM
I'm so glad you asked this question. By asking this question you are correctly stating that AC power distribution is outside of your realm of expertise and experiences. Good for you. By asking this question you may have saved somebodies life, too. Probably somebody close to you.
07/21/2014 5:50 PM
Ask joganand. You two are a match made in heaven.
Location: I live in USA, Colorado in the houses of 7 Summits
07/25/2014 3:53 AM
Current transformer is must be installed by a trained electrician or technician, only instrument type with CT's with low safety factor may be used with primary terminals. Here to connect these you can also use the strategy used in housing colonies or appartments.
Register to Reply 6 comments
Crabtree (1); lyn (1); redfred (1); ShawnHoppe (1); TonyS (1); wareagle (1)
