Previous in Forum: About Synchronous Machine Design   Next in Forum: Shunt Release Trip Problem
20 comments
System Volatege
07/23/2014 1:20 PM
In USA and Canada, the system voltage is 480V AC for3 phase system and 240V AC for single phase system, How is it possible, since the line to neutral voltage is 480/root3=277, then how it become 240V
Re: System Volatege
07/23/2014 1:42 PM
Can you please document for us "In USA and Canada, the system voltage is 480V AC for3 phase system and 240V AC for single phase system..."
This is as good a place as any to start... I guess...
Re: System Voltage
07/23/2014 1:45 PM
The word for today is "transformer".
Re: System Voltage
07/23/2014 2:38 PM
Haven't seem the movie, don't want to.
Re: System Voltage
07/23/2014 2:54 PM
Re: System Volatege
07/23/2014 1:53 PM
Re: System Volatege
07/23/2014 2:35 PM
Re: System Voltage
07/23/2014 10:08 PM
Interesting!
(spelling of "Voltage" corrected in header because I did not know how "intersting" is spelled.)
Good Answers: 42
Re: System Volatege
07/23/2014 2:49 PM
You can consult also IEC 60038 Table 1 A.C. systems having a nominal voltage between 100 V and 1 000 V inclusive and related equipment
Three- phase 60 Hz [USA, Canada]:
120/208; 240;277/480;347/600;600
Single phase:
120/240 V.
Julius
Re: System Volatege
07/23/2014 2:56 PM
I strongly suggest that you visit this site: The Basic Principles of Electricity | Anixter
A thorough reading of the many sources available on this site will reduce the likelihood of your repeating nonsensical questions.
Re: System Volatege
07/23/2014 3:55 PM
One can hope but there are always the problems of comprehension and retention.
Re: System Volatege
07/23/2014 4:15 PM
I'd get in trouble if I said what I really thought.
Re: System Volatege
07/23/2014 10:08 PM
We know that!
Re: System Volatege
07/23/2014 6:56 PM
Is this a test to discover the best S.A. answer? S.A.=Smart A$$
Good Answers: 67
Re: System Volatege
07/23/2014 8:50 PM
Volatiles. Here one moment, gone the next.
Re: System Volatege
07/25/2014 1:13 AM
You are absolutely correct.
Re: System Volatege
07/25/2014 8:07 AM
Yet people still ignore me.
Re: System Volatege
07/25/2014 9:39 AM
What was that... did you say something?
Location: I live in USA, Colorado in the houses of 7 Summits
Re: System Volatege
07/25/2014 3:22 AM
It is little bit confusing but it can be done but the main point is it is referring to the same thing, 120V is the AC voltage on a single hot wire in US home with respect to neutral, Well it is correct that in US utilities company provide a split phase of 240V AC for single phase system, it is due to they consist two legs of 120VAC for 180 degrees out from phase with one another. In US the AC power oscillate to 60 cycles per second.
Re: System Volatege
08/06/2014 2:05 AM
Hi there , some one gave you incorrect information....do you live in USA or Canada....if you dont why worry about that
Re: System Volatege
08/12/2014 7:17 AM
240/415 Volts it should be, for 3ph in UK and Oz, but not North America. There it is 2ph, so get 120/240 Volts etc.
BTW is the North American 1ph voltage 110, 115, 117 or 120 Volts? I have seen all these values quoted.
Register to Reply 20 comments
7anoter4 (1); Anonymous Poster (1); Doorman (2); europium mkII (1); Fredski (1); IdeaSmith (2); JWthetech (1); kajal (1); lyn (2); Phaddy (1); redfred (4); Rixter (1); ShawnHoppe (1); SolarEagle (1)
