Previous in Forum: Zener Diode   Next in Forum: Whats This UK Telecoms Box For?
16 comments
Programing IND780 in PLC RSLogix 5000
07/24/2014 9:57 AM
Hi,
I want to use a scale IND780 and review every data in a PLC Rs Logix 5000. I need to use a profibus network to connect them. Do anyone knows how to configure the node in the prosoft configuration builder? And which width of data transfer do i have to select?
Re: Programing IND780 in PLC RSLogix 5000
07/24/2014 11:47 AM
RS Logix 5000 is a piece of (PLC programming) software, which runs on a PC. What to you want to connect to what?
07/24/2014 12:10 PM
Hi,
I am going to use a PLC. To program the PLC I am using RSLogix 5000. So I have to sync data from the IND780 to the PLC through a profibus network. I also need to configure the network. So I am asking how that configuration is done?
In the image below is shown the network configuration window, Which width of data in the red rectangle i have to select? I am only using 1 scale, and i decided to use the type floating-point format.
Greetings
07/24/2014 12:24 PM
07/24/2014 12:44 PM
Thank you, but that part I already configured. The GSD file has the option to select many widths of data. I just do not know which width of data should I choose.
07/24/2014 2:14 PM
I always start with the average.....pick one from the middle....
07/24/2014 4:50 PM
The problem is I can not test the scale until I'm at the place where it is to be used but before that I need to do the PLC program and i can not wait until then.
07/24/2014 5:36 PM
07/24/2014 6:03 PM
Thank you.
Good Answers: 104
07/24/2014 6:22 PM
Good answer. I was going to suggest to OP that he consult the scale documentation, but you beat me to it. Here is the MT user manual for his benefit. To OP, I would suggest that you be prepared to configure the scale terminal also. Hope you have contacts at AB and MT.
07/25/2014 11:03 AM
Hi,
I have another question. The IND780 allows me to print information from the plc or do i have to activate the impression from the IND780?
Good Answers: 104
07/25/2014 5:58 PM
RTFM
07/25/2014 6:12 PM
I already RTFM. But there is no answer to that :/
Good Answers: 104
07/25/2014 7:59 PM
These terminals are generally pretty flexible. Surely, somewhere, there is a description of how the system is required to function. Surely, whoever specified/purchased the equipment had an idea of how the system was supposed to function. Elsewise, how would they have known what to order?
07/26/2014 9:55 AM
You'd be surprised what people buy and why they buy it. Most times people do not really know how things work.
Good Answers: 104
07/26/2014 12:53 PM
Scales can be used in many ways - sales/custody transfer (trucks, rail, etc), process control (level control, loss-in-weight, etc), etc. And the hardware/software can be configured in many ways (is the printer connected to the scale terminal directly?, on a network?). I don't think you'll get an answer on this forum, because that information is not available to it. I don't intend to RTFM(s), but I dare say that the terminal/PLC have the capability (if the proper interfaces are available and the devices are properly configured) of communicating bi-directionally to trigger a print operation from either end.
07/25/2014 5:59 PM
Sorry, Geez, but maybe it's time to look for a new job. Good luck.
Register to Reply 16 comments
bigg (4); hector_mesa (7); JohnDG (2); SolarEagle (3)
