Previous in Forum: Strengths of Metal   Next in Forum: Root Gap for ER70S2 Filler Wire of 2.5 mm
Does Welder Qualification Required Seperately for Full & Partial Repair
07/27/2014 8:55 AM
I wanted to carry out Welder qualification for Through thickness Repair(Root) for Cross country pipeline as per API 1104.Material: LSAW, API 5L X 52, 7.9 mm thk.Is it required to do separate welder qualification for Partial repair or the Root repair welder can carry out same. Technical reply required.
Re: Does Welder Qualification required seperately for full & Partial repair
07/27/2014 11:23 AM
Where have you looked, so far, for the answers?
That may save us all some time if you let us know what you've done to find the information.
Have you looked at the normal sources???
Re: Does Welder Qualification Required Seperately for Full & Partial Repair
07/28/2014 4:04 PM
You must initiate a mock repair and document with a WPS, PQR, WQR made by the welder who is to do repair work often this is one welder on the spread or 2 depending on pipe diameter. The second welder only has to do the WQR. All rules API 1104 apply.
Some pipeline companies fail to use this however if is a requirement by contract and was missed during estimation (run the estimator off) .
This is what I had to do for all API work that came through my shop for all in Africa / ME , Gulf and land pipeline spools etc, even though we were ASME BPV code NB, U & R .
Register to Reply 2 comments
