Previous in Forum: Dodge Man   Next in Forum: Rover Goes the Distance
9 comments
Front Wheel Drive
07/28/2014 12:03 AM
I have a 1994 honda accord automatic and would like to know if I can make it a possitrack
Pathfinder Tags: Auto Repair
Re: front wheel drive
07/28/2014 12:30 AM
In the right neck of the woods, you could chase down those guys.
07/28/2014 2:24 AM
" 94-95 Accord SiR models (sedans and coupes) included the following items: cruise control, automatic climate control (Similar to the first generation Acura CL), Bose stereo system, 7,400 redline tachometer, optional electronic traction control and optional limited slip differential for automatic transmission, optional SRS and airbags, factory installed driving lights, optional factory installed "pop up" navigation radio head unit, sound insulation liner under front hood, black-housing headlamps, no side molding was available on the Accord SiR sedan, optional rear sunscreen, optional sunroof and power retractable outside mirrors. "
http://www.andysautosport.com/limited_slip_differentials/honda_accord.html
http://www.maperformance.com/cusco-type-rs-limited-slip-differential-94-97-honda-accord-cd6-1-way-1.5-way.html
http://www.ebay.com/itm/OBX-Helical-Limited-Slip-Differential-LSD-90-93-94-97-Honda-Accord-DX-EX-LX-SE-/171061807679
http://www.driveaccord.net/forums/
http://honda-tech.com/
http://en.wikipedia.org/wiki/Honda_Accord
Good Answers: 11
Re: Front Wheel Drive
07/28/2014 9:52 AM
The Redneck way: Take the FWD Differential Apart and weld the side gears and pinion mates to each other. Of course, it won't corner very well afterward.......
People Living in Competition, All I want is to have my peace of mind - Boston
Good Answers: 123
07/29/2014 2:31 AM
You can find the locking differential you want through the many aftermarket Honda parts suppliers. Having it installed is not an inexpensive procedure. Installation requires very exact mearurements to set the ring and pinion exactly right. The price of the part will be only half the cast, as you will find out. Why do you need a locking differential?
Bob
07/29/2014 6:47 PM
On heavy exceleration it pulls really hard right and only spins one wheel...
Good Answers: 123
07/30/2014 1:18 AM
Have you changed the original wheels on the car? Torque steer is affected by the wheel offset. Early Mini Coopers were almost uncontrollable under WIT driving in city traffic.
When GM brought out the Toronado, the wheels looked like the inner wheels from a duel wheel truck. But, they had taken out the torque steer. Who else do you know that is driving a setup similar to yours? How are they dealing with wheels and tires? Unless wheel-spin is way out of control, more offset, and wider rubber will cost lots less, and should eliminate most of your issues. Good luck.
Bob
07/30/2014 12:28 PM
OK I appreciate all the comments from everyone but I really just wanted to know it I could change my transmission to a LSD or posi track drive...Again thank you everyone for your help, the car is a project of mine and I don't want to get rid of it....
07/29/2014 11:02 AM
Your FWD is already pretty stable, but here is a link:
http://www.andysautosport.com/honda/1994_1997_accord/drivetrain/differentials/limited_slip_differentials/
Have you considered any AWD models, or just buying a Subaru?
EDIT...oops, someone already linked there!
common knowledge...less common than common sense
07/29/2014 4:56 PM
I'd be surprised if you couldn't get one from Quaife. They are not cheap but the V-dub enthusiasts love them.
http://quaifeamerica.com/parts/honda-acura?page=1
Good luck with your quest.
Register to Reply 9 comments
Anonymous Poster (1); AverageJoe (1); bob c (2); Brave Sir Robin (1); Nosmo64 (2); SolarEagle (1); The.Tinkerer (1)
