Previous in Forum: 3ph Heater Elements   Next in Forum: Demagnetiser Design.
12 comments
Intensity of the Magnetic Field
07/31/2014 10:40 AM
Dear all
good day
We checked the intensity of the magnetic field in the 400 KV network and found that the field strength of phase R much higher than the other phases and in multiple places in the network, please what is the possible causes
Good Answers: 143
Re: intensity of the magnetic field
07/31/2014 11:32 AM
It's simple physics. If Hi is higher, then Ii is higher. Your network is probably unbalanced.
07/31/2014 11:43 AM
Current is higher or you're not measuring the field strength at the same distance, R, from the conductor. The H field drops off as 1/R.
07/31/2014 7:10 PM
Dear sir
thank you very much for your response
but ,please what mean by (The H field drops off as 1/R.)
thanks
07/31/2014 8:57 PM
I will try to explain it. A current flowing through a wire creates a magnetic field that circles the wire. We call this field the H field. It is a vector field, meaning that at any point the field has a magnitude and direction.
If you take a circle centered on the wire and you multiply the H field tangent to the circle times the circumference of the circle, it gives you the current flowing through the wire (by Maxwell's laws). The further you are from the wire, the larger the circumference (C=2πR), so the H field will be inversely proportional to R. The circumference times the H field will always give the same answer for the current. (This is called a line integral)
You may be more familiar with the B field. The B field is the H field multiplied by the permeability, μ, (which depends on the material). B=μH.
Re: Intensity of the Magnetic Field
07/31/2014 11:59 AM
And other ferrous metal in the area could affect your readings.
Good Answers: 445
07/31/2014 1:39 PM
Is your 400kV network overhead, underground, GIS? What is the configuration of the lines, trefoil, flat, transposed? How did you get close enough to a 400 kV line to measure the field intensity of each phase? Don't forget that a Hall-effect Transducer will show the vector sum of the magnetic field from all sources combined, and distance matters a lot.
07/31/2014 7:47 PM
Dear sir
Thank you for your respone
our 400kV network is overhead line, configuration of the lines is triple wire for
each phase,when i measured the Intensity of the Magnetic Field by 3D
measurement of the magnetic field(Gauss meter) i stood under phase /R
then phase /S then phase /T .In other words,the distance for all measurment was
symetrical
Good Answers: 445
07/31/2014 7:59 PM
Thanks for the feedback! So your OHL is configured flat like this O----O----O and is ordered R-Y-B. Where is the tower in relation to the conductors? What is the distance from the middle phase to ground, and are there any underground conduits/pipelines running parallel with the phases? How long is OHL and are there any transpositions? Did you also record the individual line currents during your tests?
08/01/2014 8:29 AM
If the lines are side by side, then it's not really symmetrical. What are the distances between the wires compared to the height? Any reading directly underneath one line would also see the field from the other lines, depending on the distance of separation, and the center line would have more interference.
I would be suspicious that the electrical field would interfere with the electronics of your current sensor.
Here is a paper on remote sensing of current on lower voltage HV power lines. The sensor must be mounted on the power pole closer to the wires, and the geometry is taken into account in measuring the currents.
http://www.cired.net/publications/cired2001/1_55.pdf
08/03/2014 6:24 PM
Dear sir
Thank you for your interest
but the problem now, when we need to open the control panel door for 400KV
circuit breaker which that place approximately under the wire for the R/phase
We feel the presence of electricity and we can not touch the door knowing that the
door grounded.
best regards
Good Answers: 445
08/03/2014 7:12 PM
That is a totally different problem, your cabinet is not properly bonded and/or grounded, you are feeling what is known as "touch" or "step" potential.
07/31/2014 11:27 PM
Does the measured value of magnetic field include that(how much) of the earth?.
pnaban
Register to Reply 12 comments
ASSER (3); pnaban (1); RAMConsult (3); Rixter (4); TVP45 (1)
